HDI starting woes....
Kayleys car has been in hidernation for 6 months in a garage while she has been to france to work
when storing it we did the normal stuff, like fill it with her stuff and drive it and park it up,
We took the battery off and placed some cat litter in trays to soak up any moisture that would appear
so today is 6 months on and today was the day to dig out the car, get it started and bring it home,
took the fresh charged battery down connected it up, turned it over,and over, and over NO GO!
al the lights in the right place, tank pump spinning up, but still nothing.
we knew the fuel gauge was broken so had another pump sender unit to fit
but we could hear the pump spinning!
decided to go home and get peugeot planet as i feared the wost that the ECU had lost its IMMO codes being disconnected for 6 months from the battery
nope not that! scan the ecu for faults nothing that would stop the car........
Live data Fuel pressure request 300bar actual 0bar............oh fuel pump?
took of the feed pipe to the filter no flow!
took pump out the tank as it was going to be replaced anyway....................
SOME ONE HAD SYPHONED the tank dry! ............bastards
15ltrs of fuel into the tank with the replacement pump
and the car started first try after priming the system
moral of this story
Keep it simple stupid!
GTI6 Info
Sneaky b*****s how did they drain the fuel? Just pulled the filler cap open and hose do you think? Good thag you got it started though. Looks really good!
car has been in a small garage for 6 months the car doors wernt locked so would of been easy to open the tank and syphon,
only a few people knew the car was there one being my gran as its her garage, but its highly unlikely to be her as she cant walk without the aid of a frame
diesel dont just get up and walk without help
GTI6 Info
That’s bloomin shady that is!
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
any "trsvellers" nearby?
Hate Housework!
I hope whoever siphoned it off got rewarded with a gob full of diesel!
  Oil brether woes dr_jekyll 8 2,882 01-02-2017, 04:57 PM
Last Post: dr_jekyll
  HDi woes vlj 4 1,595 24-05-2013, 05:49 AM
