Uprated dampers on standard springs?
You see allot of people put lowering springs on standard dampers but is it okay to put standard springs on uprated dampers?
I've ordered some KYB Ultra SRs for my gti6 and got some OEM springs will that be an okay combo?
you may get a stiffer response over bumps Itwasntme
Hate Housework!
Yeah I thought stiffer... I wonder if the ride height may be a little higher not allowing the springs to be compressed to standard height...
I think Magenta was being rude gti6man ....or is it just my filthy mind?!!  Rofl
Everything I can see about them suggests they are a non-adjustable replacement for standard shocks and hence appropriate for use with standard springs.  Ride height shouldn't be affected.
I believe their description as being 'for the sports driver' with 'harder damping force' just means they won't allow the spring to compress (or extend?) as quickly.  As such they should give a more controlled feel on a smooth road surface but may mean you have less grip on a s**t one!!
(02-02-2018, 05:32 PM)Mighty306 Wrote: I think Magenta was being rude gti6man ....or is it just my filthy mind?!!  Rofl
I know what was in my mind - - - Rofl
Hate Housework!
They will be fine, they're just OE replacements with a stiffer foot valve.
  whats the best dampers and springs procta 13 2,177 07-01-2016, 08:13 PM
Last Post: Mole man
  Droplinks.... buy standard or are there uprated?? Shea 22 8,961 28-03-2013, 08:41 PM
Last Post: Frosty
  dampers. kingy 7 2,987 08-03-2012, 09:44 PM
Last Post: kingy
