Boost pipe pop
Boost pipe pop
Right guys just upgraded the map to stage 2 and guessed it i found the weak point on one of the boost pipe. My own fault forgot to fully tighten it enough so as soon as 20psi hit a few times pop it went.
My question is since re attaching and checking all the joints. It now doesn't seam to pull as hard.
What damage can be done and what areas should i take a look at.
Boost pipe popping off cant really cause damage unless you continuend to drive and suck something in. Check all other joints as well more than likly loose or leaky
^^ That, it's likely you've still got a small leak somewhere
  Lower boost pipe options. bashbarnard 12 2,777 12-10-2015, 07:14 PM
Last Post: ccr24
  Boost take off pipe Connor 21 2,024 03-11-2014, 09:16 AM
Last Post: cully
  Boost pipe popping off Jtrigga 6 1,554 02-09-2014, 09:05 PM
