Citroen bx 1.9 turbo diesel SOLD
FOR SALE
SOLD SOLD SOLD
Orginally I bought this as a 1.9 straight diesel, it was fantastically slow, struggled to keep up with the moden traffic, 2,000 miles later the fuel pump started leaking, so I found an engine and did the engine conversion. So spec is as follows
107,000 miles
Mot till 31st of July
Front electric windows
Electric sunroof
Central locking
1.9 xud9te from a 405
1.9 nad cam
Bosch fuel pump
306 hdi gear box (longer ratios)
Xantia inlet manifold
Front mounted intercooler
Boost gauge
Water temperature gauge.
Defiltered turbo
Straight though exhaust system with one silencer  (home made)
Powerflex red lower engine mount.
Manual boost controller.
Spoiler (not attached)
During the conversion the engine had a full new cambelt kit including tensioner and pulley, also water pump. I also fitted a brand new valeo clutch kit, new genuine  drive shaft seals, new gear box oil
Had new oil and filter at 105,000miles, also had a new ball joint passanger side at 102,000 miles and a new ball joint drivers side at 106,000 miles. It's had new hand brake cable drivers side.
The car has been well looked after by the previous owners, you can certainly tell this just by looking at the paint work.
Bad bits
The drivers side A and C pillar trims have broken (broke these when I was cleaning the sun roof drains)
Body work has its small dings and dents (it is 25 years old)
Tiger seal on boot lid were I'd fitted a spolier but it soon come off (needs bolting on)
Knocking on front end suspension  (but comes with 2 brand new wishbones, 2 brand new anti roll bar links, 2 brand new track rod
It needs some tlc on a few other bits but still used daily with out issue.
£750
Location Chesterfield
[Image: 20161218_134808_zpsnaoaxhkj.jpg]
[Image: 20161218_134817_zpsxg1x9hrx.jpg]
[Image: IMG_20161210_192501_zps2facpthq.jpg]
(Flat plate heater has been removed, but have a spare one I could include in the sale)
Now on eBay 99p starting bid
Look at this on eBay http://www.ebay.co.uk/itm/252739729870
  *SOLD* HDI D TURBO ASTOR GREY £350 doogle-d turbo 11 4,939 04-10-2018, 07:20 PM
Last Post: daddyfixit
  Citroen zx volcane 1.9 turbo diesel Chris_90 4 2,319 26-02-2017, 09:47 PM
Last Post: Chris_90
  2002 206hdi D-Turbo 3dr **SOLD** Iceman299 3 2,350 30-10-2016, 10:03 PM
Last Post: Iceman299
