Small play in rebuilt beam?
So i put new bearings and shafts in my beam and there is a very slight bit of play in both trailing arms.
Has anyone had this before and is a small amount of play normal?
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
No amount of play is normal.
Stef maybe along to help diagnose though
What bearings and trailing arm shafts did you use? Genuine??
Figured that much alryt. Just that it is so minimal and is gone once torsion bars and arb is fitted is why I asked.
Got them on ebay about a year ago, think they cane from poland but i had seen other people that used them with no problems.
did you check to see if the tube warn before pushing the bearing outers in ?
GTI6 Info
No didnt check the tube, just presumed it was alryt because old shafts were'nt bad at all. Dont know now shud i sort a new beam or put this one on and run it in for test.
check the offset washers are the counter sunk type, ive had many 306 axles fitted with 106 non countersunk type and these are thinner giving play.
As said above no play is normal. did you refit the inner bearings at the correct height and the shaft into the arm at the correct height aswell?
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Yeah all of that was right. Found the problem after. The 2 torsion bars ore loose in the axle, the splines must be worn down or something, heres a link to the video of it:
https://youtu.be/OukV1m8JMzM
needs pulling apart regardless, possible worn splines on either arm and bar.
05' Evo 9 IX GT
Team eaton.
It looks like the splines in the arm are the culprits. I have more arms here but there all drum brake.
  Best Rear axle rebuilt kit? mcilroy 7 2,194 26-01-2017, 07:36 PM
Last Post: mcilroy
  Wheel wobble/play mcglynn 11 2,317 04-10-2014, 08:52 PM
Last Post: mcglynn
  Play in wheel adamm306 78 15,355 08-09-2013, 11:12 AM
Last Post: adamm306
