406 Brembos with Nimrods
Hi
Possibly looking at 406 V6 Brembos eventually but have read about clearance issues with the spokes and wheel size.
I'm running 16" 206 Nimrods at the moment and no spacers on the front so ET if I remeber correct is 25 (I think)
Would there be any issues at all or would these literally be a bolt on and use the Xantia V6 discs?
Thanks
Luke
Should fit behind 16" alloys iirc and any other problem should be solved by spacers. I dont know much about offset etc so dont take my word for it but that is my thoughts!
I would have thought yes to the 16" as well as the shark fin alloys off the 406 are 16's but couldnt remember if they are from the V6.
Anyone know the ET of the shark fin alloys as these would clear it I reckon so I can see if spacers are required and what size if so
Any good? http://www.carlsalter.com/peugeot-wheel-fitments.html
[Image: Signature.jpg]
TheGateKeeper Wrote:Any good? http://www.carlsalter.com/peugeot-wheel-fitments.html
Thanks Smile
Looks like 10mm spacers to me if I'm remembering ETs correctly
Would need new hoses as well
Either with a banjo end or to fit the metal link pipe, all items I cansupply
et20 or 28 i think
[Image: sign.png]
↑ Project ↑
Iirc you need a 20mm spacer with cyclones which would make it ET -2 so im guessiyou wouldnt get away with no spacer on a nimrod
  Fitting challengers on 406 Brembos Teddy 0 1,034 03-05-2018, 08:34 AM
Last Post: Teddy
  406 brembos Bigcjlad 2 1,467 06-08-2016, 11:35 AM
Last Post: Rippthrough
  Min wheel size for brembos dr_jekyll 31 7,465 20-03-2016, 07:48 PM
Last Post: welshpug
