Standalone coil pack
Hey guys,
Ineed to find a remote coil pack with ht leads to fit the gti6. Needs to be wasted spark. Any suggestions as to what is usually used?
IIgetting misfiring with the xsi packs so want to try something else.
Ford packs can be used i think. Not aure what ones though
well ive done it now. 106 s2 coil pack and corsa ht leads. If the corsa leads arent good enough ill swap them for something bigger. Seems to be the standard route for people doing what im doing. saved £25 and cost about £70 for the lot from ecp.
That's what I have, any 8v Tu pre COP, or any 8v XU wasted spark coil.
Ford coil can work but it needs that silly ford specific plug, no idea what leads youd use on that.
Yeh I looked at the first stuff and most aftermarket options like map used the ford oval plug. I'll try this setup first and see if it fixes it.
does it have to be coil and leads??
(21-09-2016, 03:56 PM)fatlapit Wrote: does it have to be coil and leads??
Ive already been using the xsi pack. Is there another one piece pack that fits?
whats wrong with using the xsi unit? why the need to change?
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
(21-09-2016, 04:27 PM)Stef205 Wrote: whats wrong with using the xsi unit? why the need to change?
ive tried two now and when the engine gets warm it starts to misfire. Not sure whats going on so want to try a different setup.
head-gasket?
GTI6 Info
(21-09-2016, 04:40 PM)cully Wrote: head-gasket?
is this a genuine suggestion?
yes!
also may need of a decoke carbon glows hot pre igniting the fuel causing a misfire
GTI6 Info
I've heard good things about "sea foam" to decoking motors.
I use the xsi coil never let me down bud. Your plugs could be the wrong heat grade
ive used it for over 7 years now, sounds like another issue rather than the coil pack
05' Evo 9 IX GT
Team eaton.
check the condition of the plugs, stick a picture up.
I would not be surprised these days if cully was on the right lines, though in my experience they tend to miss when cold due to coolsnt seeping into the cylinder at rest, if they are holding some compression the misfire can often clear as they warm up and burn off the coolant.
until its a proper loss of compression where the misfire is there all the time.
it could be as suggested also the plugs, if the map isnt great and theres too much fuel in certain areas and the tenp scaling is off they can foul up quickly, running a hotter standard 6 grade plug can alleviate this though your total advance figure may be too much if they have pushed it.
Plugs are brand new ngks from ecp. Had two sets in to bebsure
if the engine has run, they're not new any more Wink
standard bkr6ek?
do a compression test cold then hot
poor injector could give a misfire
clutching at straws
GTI6 Info
I've got a compression tester you can borrow if needed. I don't see it being hgf though in all honesty. This issue has been around for months now, hg wouldn't last that long under abuse without further signs IMO.
bcr8es are the boys
(22-09-2016, 07:58 AM)fatlapit Wrote: bcr8es are the boys
im using bkr5ez
im using bkr5ez
probably your problem
BKR6EK is std
5 will be too cold
GTI6 Info
so what should i be looking at? the 5 plugs im currently using are the standard ngk option from ecp.
"Some manufacturers numbering systems are opposite the other - for Champion, Autolite and Bosch, the higher the number, the hotter the plug. For NGK, Denso and Pulstar, the higher the number, the colder the plug."
Right ive ordered some BKR6EKs on next day delivery and will give those a go.
5's!!! thats hooter than oem! no wonder! try some bcr7es. 8's are ok for track when flat out all the time and cylinder temp is higher 7's are good for everyday. Ive used 7's for years as niall did in his.
Try ngk 3330 bcr7es
05' Evo 9 IX GT
Team eaton.
5's were never listed for a 6 so god knows how they managed that, as said, they're a hotter plug.
also, they're fecking expensive!! ngk's are half that at my local motorfactors.
I never realised there was so much variation in a spark! Confused Thought it was only the gap that made any difference, I've learnt something there.
gap doesnt specifically make that significant a difference unless its way out of spec, and plugs are pre-gapped these days and arent designed to be adjusted anyway, the earth electrode is too brittle.
unless the boost squashes them like mine now and then lol
05' Evo 9 IX GT
Team eaton.
sure its not your pistons twatting them? Big Grin
Shocked Gti-6 coil pack change, help please GtiJimmy 12 5,084 27-04-2016, 09:39 PM
Last Post: cully
  Is this not a gti6 coil pack? underground375 4 2,008 02-05-2014, 08:57 AM
Last Post: underground375
  standalone engine management? sam 41 12,573 27-03-2013, 12:31 PM
Last Post: sam
