04-08-2016, 06:24 PM
Can someone help me and tell me what wheel nuts I need to fit cyclone alloys ???
Wheel nuts
04-08-2016, 07:32 PM
Tapered Bolts... Do not use flat seated iirc
04-08-2016, 07:50 PM
(04-08-2016, 07:32 PM)BiG K Wrote: Tapered Bolts... Do not use flat seated iirc wrong, well mostly flat seated to fit clones. the later ones had flat seated taper that you can just use the flat seated type on as well. hope it helps
clones use flat seated bolts!
there are two types of clones early/late early clones take parallel threaded flat seated bolts later clones take stepped parallel flat seated bolts later bolts will NOT fit early clones early bolts fit both types of clones more info here http://306oc.co.uk/forum/showthread.php?...#pid329124 https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
05-08-2016, 06:09 AM
(04-08-2016, 07:52 PM)cully Wrote: clones use flat seated bolts!Where's the best place to buy them ??
05-08-2016, 08:41 AM
forums, facebook, peugeot
05-08-2016, 08:49 AM
hmmm i'm a little worried now... as i've fitted my clones straight on, but didn't have any idea about the nuts issue?
i'm assuming mine are ok being they have gone straight on and bolted up?
Swallow bolts are also flat seated, you should be fine Pocketfighter.
Rob, which wheels do you currently have? A 1.9 HDi doesn't exist so I can't work it out from your car spec lol. The alloys all come with flat seats, steels come with tapered. As for where to buy them - not Peugeot unless you're feeling rich, the chromed bolts cost £6 each!! Thanks given by: PocketFighter
05-08-2016, 09:38 AM
You learn something new every day I guess.... why must Peugeot make everything so complicated!? lol
05-08-2016, 10:05 PM
(05-08-2016, 08:54 AM)Toms306 Wrote: Swallow bolts are also flat seated, you should be fine Pocketfighter. Sorry 2.0 liter and got steels on. I rang Peugeot and it came to £64 !!!
05-08-2016, 10:13 PM
Bargain, they must've dropped in price since I had to buy some...albeit 7 years ago now!
Ebay or facebook you can probably get a set posted for £20 give or take. |
Removing locking wheel nuts? | Colactix | 12 | 3,101 |
13-03-2021, 01:30 PM Last Post: Colactix |
Wheel Nuts? | JTaylor2005 | 20 | 3,521 |
14-05-2015, 06:58 PM Last Post: Toms306 |
wheel nuts | thebluepearl | 0 | 1,002 |
10-10-2014, 07:55 PM Last Post: thebluepearl |
