cully's New boat!
cully's New boat!
as the daily died i needed something to drive to work as the 6 would get a bit expensive,
so i took the opportunity to change to a bigger bus as i need to tow a caravan to Sussex this weekend
so here it is....
2ltr TDCI 130
so plans.....
oil and filters drive it to work for a week
if it lasts the week its towing to Sussex on Saturday morning 210 miles with a caravan 420 miles round trip
further plans will be made Monday the 9th if it returns under its own power Big Grin
GTI6 Info
Injectors.
(03-04-2016, 07:02 AM)JJ0063 Wrote: Injectors.
Second this.
instead of saying injectors care to expand your comment a little ?
GTI6 Info
Injectors often die.
so i need to get to get software and a cable and learn how to program second hand ones Wink
GTI6 Info
'Spose.
Nice taxi anyway.
work taxi Wink
GTI6 Info
Christ guys always look straight to the negatives.
I know the car and it shouldn't be a bad bus. Cheap car at the end of the day.
(03-04-2016, 07:48 AM)JJ0063 Wrote: Nice taxi anyway.
From an ex-Vectra owner? Tongue Rear calipers and springs seem to breaking more often than injectors now. Not that any of that is hard or expensive to replace. Think you can recode injectors with FORScan anyway which is free. http://forscan.org/
Nice Jag X type in a Mondeo bodykit... Big Grin
LOL @ frosty as his name is on the last MOT sheet!
Cheap purchase runaround that was the intention
GTI6 Info
well... i guess it does the job. Just not very inspiring.
and I was thinking you'd bought something that floats :/
Hate Housework!
(03-04-2016, 08:57 AM)cully Wrote: LOL @ frosty as his name is on the last MOT sheet!
Haha we did wonder if you would notice
I like the mondildos. If you compare them to a vectra they are incredible.
They're good cars if the engine has been looked after TBH, just not very inspiring.
Decent cars, thought you'd have got a 406 though if you were after something like that. Can't kill mine!
went out to fit an EGR blank plate, and there was already one in there! LOL
the one in there was made of steal and quit corroded so replaced it with the nice stainless one i made.
battery died when i left work earlier had to push start the heavy thing!
seems someone had fitted a leisure battery instead of a cranking type car battery,
so swapped the battery from the HDI and fitted a new air filter and a handfull of lamps to the rear clusters
also seams to have a clonk in the rear i suspect its a droplink sounding off
will investigate that one at some point.
any more surprises to expect Frosty??
GTI6 Info
Cant remember tbh, done a few mot's since then.
to be fair they arent that bad but we see so many injectors in at work failing i do only see the negatives. apart from that its one of the better fords from this era
These and the jags suffer with rear bushes, which that sounds like.
As other have said, if the HP pump and injectors don't die they are really decent cars. My dads one get over 40mog towing a caravan!
Knowing the previous owner's son... Baler twine is order of the day!!
Injectors, egr and dmf are the only issues I know of with these...
Drive well tbh. Boots are huge too
My uncle had one, the list of faults are :
3 snapped coil springs (they're prone to going)
Injectors failed (tell tail sign is the glow plug light starts flashing under acceleration) £800 with recon injectors
PAS pump pulley failed
Starter motor, followed by DMF
Blocked dpf regularly
Turbos prone to clogging up and need stripping and cleaning
Old housemate had one of these. Is it the 130 that have the 6 speed box?
Despite it being a weird urine yellow colour and leaking badly whenever it rained (all the silicone sealant and ford themselves couldn't get it to stop) the car was a trooper. Run on a student budget so very little care given but kept on going.
Was a very comfy and easy car to drive as well despite it's size. Have very much considered a ST TDCI version for a daily
[Image: mcetg0.png]
yes 130 with a 6 speed cruises on the motorway at 2000rpm sipping the diesel
GTI6 Info
Is the 2.0 much different to the 2.2?
As Dad's ST was pretty much fine the whole time he had it (5 years). We did have to change the EGR but compared to what everyone is listing in here, it was no bother.
been out playing well fixing bits
i now have full working central locking Smile
including the boot lock/unlock from the key and from within the cabin via dash switch
all doors and no door warning lights on the dash!
the clonking is not the drop-link it is the strut top mount
there seems to be a loose section of plastic in the centre which i think is part of the inner of the spring seat guide that holds the dust cover boot
i can live with that now i know its nothing serious
may look at changing it before the MOT.
I've found and changed the pollen filter
just started to look at the reverse light problem looks to be the gearbox switch so il order one of them too
cant believe how much bigger than the 306 it is
it is taking some getting used too
GTI6 Info
the car has played a blinder all weekend!
hitched up the caravan left home at 12:00 on Saturday arrived at site after two stops on route
unloaded, and sited van set kayley for the night then went and found out premier inn Smile
sunday was sorting the van electrics ect going into town to sort some last bits then around 5-6pm we set off home leaving kayley too it
M23-M25-M4-M5-home just got in the door at 22:00
total of 530 miles half with a caravan on the back I must admit the Mondeo is a comfy old beast for that sort of miles
need to fill the fuel to work the mileage out as we used just over a tank of fuel
Smile
GTI6 Info
looks like the mondeo is staying for 12months!
failed its mot on a loose strut pinch bolt!
done it up in front of the tester while on the mot ramp
passed with two advisory s
tyre near limit 2mm
drive shaft gator holed
GTI6 Info
  Project (3) 306 boat. time to make it float :-) pioneer DJ paddy 53 18,391 24-09-2020, 10:27 PM
Last Post: ekjdm14
  cully's next project toy! cully 12 3,194 19-06-2014, 10:07 AM
Last Post: tenwierdufos
