Rear caliper yoke bolt spec
I'm looking for the spec of the 2 bolts that hold the carrier onto the caliper (they face forwards from the rear of the caliper)
I can't see them on servicebox, think they just come in the caliper 'kit' and aren't available separately.
Want to clean the threads on one side of my estate and checking  I have the right tap for the job.
part number is 444973 caliper fixing fit consists of 2 bolts and bolt bracket, youll need 2x for a pair of calipers
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
The other bolts sorry, the ones that would be above the bleed nipple (part 12/13) but are not shown:
[Image: uyUWZwM.png]
in that case 4405 30
05' Evo 9 IX GT
Team eaton.
How can I find the spec from servicebox?
I can search and find the price of it, but no link to spec?
It's the spec I'd like to know,
spec as in bolt grade, size, length and pitch?
05' Evo 9 IX GT
Team eaton.
exactly that info yes, please.
slightly joking, what other spec would there be? colour? weight? political stand?
grade:- is 8.8 but you could fit anything from 4.8, 8.8, 10.9, 12.9.....
bolts are pennies from dealers so i dont understand why you need the spec of it
05' Evo 9 IX GT
Team eaton.
ok thanks mate.
Bolts are £2.76 each, I just want to know the spec to see if I can clean out the threads with a tap.
Bolts are pence from suppliers, not pence from dealers, but if I don't know the spec how can I order?
spec is, from a 205 page on servicebox: diam 12x150-79
79mm long seems a bit big? but the M12 and pitch sounds about right.
(24-02-2016, 09:55 PM)tigerstyle Wrote: spec is, from a 205 page on servicebox: diam 12x150-79
That's because 440530 is the bolt that holds the caliper to the trailing arm, not the one that you're after which if I've understood correctly is the two that holds the pad carrier to the caliper body, correct?
That's more like about 20-25mm long but I can't see it listed anywhere on Servicebox as you've found. I can double check later for you if required though as I've got a caliper in pieces in the garage so have one of those bolts available to measure.
Servicebox actually shows that part number for both the carrier-to-the-caliper as well as the caliper-to-arm bolt on the 205 page.
Got one here in front of me, Grade 8.8 M12x1.5-26mm long with 8mm plain shank. A quick Google suggests it's a unique Peugeot bolt!
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
So it does, not shown on the later cars though for some reason.
(25-02-2016, 11:24 AM)powerandtorque Wrote: So it does, not shown on the later cars though for some reason.
Misleading schematics & unique bolts......typical Peugeot!
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
  Rear brake caliper overhaul Mighty306 18 5,931 19-02-2018, 10:55 PM
Last Post: Mighty306
  Rear caliper piston dust boot Dangti6 3 1,410 02-05-2016, 03:15 PM
Last Post: Stef205
  rear brake caliper bolts procta 3 1,258 25-06-2015, 07:27 PM
Last Post: welshpug
