Central locking keeps locking itself
My pug has developed an annoying fault, the car just keeps locking itself. Sometimes it does it as soon as you unlock it sometimes it's a few minutes. Seems to be getting more often, it developed this fault a few months ago but sorted itself but now it's back. Started doing it after I loaded some rims into my boot, lowered back seats and I think it started doing it last time after having stuff in the back as well. Checked and my locking unit isn't under the seat I don't think so maybe just a coincidence.
My keyfob doesn't working, well it does but drains batteries in a day so I unlock it with the key.
Any help would be good as it's super annoying.
Somehow you managed to post the same thread 3 times, but I've removed the duplicates for you.
You'll probably want to start by checking the state of the door looms tbh, could be a broken cable.
Thanks mate, I was trying to find the delete button myself when I realised what I'd done.
Hi
Anybody know where to find the central lockingbox on a 1999 Roland Garros Hatchback?
If it's a phase 3 model it'll be part of the CPH unit under the clock. You have to remove the centre gear stick surround to get to it.
I know the Phase 1 car used to have it behind the rear seat base.
(20-04-2016, 11:21 AM)DeeTurbo Wrote: If it's a phase 3 model it'll be part of the CPH unit under the clock. You have to remove the centre gear stick surround to get to it.
Thank you.
its not under the rear seats,cant find it.
So near the ashtray?
Hi under the clock it´s the airbagcantral Smile
Anyone know where to look. Not under driverseat either or rear seat?
its above the airbag ecu behind the low row of switched in the lower dash
black box fixed with 4 upward poking screws
GTI6 Info
Thank you
Thank you
Hi, I found the box Black, like a big matchbox. I disconnected it.. It´s wierd it still (works) like before.? (locks/unlocks)
Is it a two piece.... another box??
Tahnks.
(08-05-2016, 06:44 AM)Lars Wrote: Hi under the clock it´s the airbagcantral Smile
Thank you
Tahnks.
It only has one connector ?
it should have two plugs. you must have the wrong box.
[Image: IMG_20130210_162932_zps82fc2e28.jpg]
[Image: IMG_20130210_162916_zps8a81e00c.jpg]
The box I found was half size I must look again.
Thanks for the photosSmile)
The box wasn´t there ? Any suggestions where to look? Smile
Not under the watch, not under rearseats or frontseats Smile
Could it be in the door???
Probably different placing on a left hand drive model...
P1 XSi track car
2.4 LWB T4
  Central locking/deadlocking/immobiliser going beserk. pug306driver 5 2,143 29-01-2022, 09:29 PM
Last Post: pug306driver
  central locking bypass auto unlocking andyw 1 1,293 04-07-2021, 03:58 PM
Last Post: Mighty306
  Universal remote central locking carrot 1 1,634 19-02-2021, 07:58 AM
