Rear beam stiff on one side
Hi,
Ive got a 306 hdi estate and the rear beam is really stiff on one side only
The stiff side literally doesn't move so making the ride really hard (unbearable) over any type of bump / pothole.
From reading I can see this is probably down to worn trailing arm bearings? would this cause the axle to not move what so ever?
I was hoping that it would be a seized shock absorber, has anyone ever had the same symptoms from a seized rear shocker?
When I jack this side up the wheel doesnt move what so ever so dont really have to jack it very high.
The other side you have to keep jacking as the suspension is depressing.
Any help will be much appreciated.
beam is screwed. if its that siezed its probably done the cross tube in as well. either source a second hand beam or speak to stef on here. he rebuilds them for a budget cost for members only. and apparently does a cracking job.
Have you tried the shock?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
I highly doubt its a shock not seen one thats just given up and seized worth unbolting one end and checking it moves tho.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
I can confirm sadly that it is the trailing arm that is seized!! Could this axle still be rebuilt?
Doubtful to be honest
With out pulling it apart or in this case beating it apart! you cant really say but as paul says its very unlikely
05' Evo 9 IX GT
Team eaton.
has some bugger welded the arm on that side??   how long you had the car?
Had the car 3 years so sadly no welding there, just seized itself solid!! Sad
Looking at getting a 2nd hand axle now.
Is there an easy way to tell if there f*cked whilst there off the car? Without stripping it right down? Thanks
Go under the car you intend to take the beam from and push the body up and down, if it creaks...move to next 12+ year old 306 and hope thats not the same Wink
(22-08-2015, 08:12 AM)WILL1000 Wrote: Looking at getting a 2nd hand axle now.
nope.
Lol didn't read it all haha,'off the car' being the clue Big Grin
there is no way when its on the car either.
(22-08-2015, 12:42 PM)welshpug Wrote: there is no way when its on the car either.
lmao Yes there is. A f*cked beam will have symptoms like all suspension does when it's f*cked. Knocking, squeaking, play in the trailing arm, camber etc.. I accept it's hard to tell and yes, off the car it can be very difficult/impossible to tell.
  Rear beam ...the good and the bad Mighty306 35 15,522 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 1,429 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 6,666 18-03-2019, 03:40 PM
Last Post: MOK
