16-04-2015, 01:37 PM
Been doing a bit of research and have made a little discovery.
This will only work on PULL type clutches eg:S16 GTI6 Dturbo . NOT HDI (as this uses a push type clutch)
As i'm converting my HDI to a pull type clutch and GTI6 flywheel this will work perfectly.
Now this is the cable I used (Citroen ZX 16v BE3 Pull type)
![[Image: 20150416_132400_zpskjvmqqep.jpg]](http://i1224.photobucket.com/albums/ee365/paul13205/20150416_132400_zpskjvmqqep.jpg)
There's differences in the bung which goes into the pedal box, also a slight difference in diameter on the plastic part:
Left = ZX cable
Right = 306 Dturbo
![[Image: 20150416_131834_zpspt6cfxke.jpg]](http://i1224.photobucket.com/albums/ee365/paul13205/20150416_131834_zpspt6cfxke.jpg)
Remove the bung on the ZX cable and slice it off
![[Image: 20150416_132215_zpsfnnamj2y.jpg]](http://i1224.photobucket.com/albums/ee365/paul13205/20150416_132215_zpsfnnamj2y.jpg)
Remove the 306 bung by sliding it off, over the plastic clip. No need to cut it (ignore the hack saw blade.
![[Image: 20150416_132219_zpsdesc5my7.jpg]](http://i1224.photobucket.com/albums/ee365/paul13205/20150416_132219_zpsdesc5my7.jpg)
Slide the bung over the end of the ZX clutch cable, now this is where the slight difference in diameter causes a slight issue but i was going wrap a bit of insulation tape around the plastic part so the bung sits central. I cannot see this causing an issue. Or may finding a thin plastic sleeve to take up the gap.
![[Image: 20150416_132335_zps6dw1jydv.jpg]](http://i1224.photobucket.com/albums/ee365/paul13205/20150416_132335_zps6dw1jydv.jpg)
And voila! Finished item. A adjustable pull type cable for a BE3 box .
I'll be fitting in the next few weeks.
Left = ZX cable
Right = 306 Dturbo
