HDi rods and Uprated XUD engine mount, 206 gti nimrods
Got two sets of HDi rods with good second hand bearings. One set is from a citroen c5 110 hdi, the other set from a citroen xsara 110 hdi. Both are a direct upgrade for XUD conrods.
£45 a set posted
Also got an XUD rear engine mount with a brand new ecosse (think its baker bm) solid rubber (not poly) bush. Was going to use myself but hdi engine mount is different!
£35 posted
Also I have loads of wheel bolts, steel and alloy wheel types, alternators, starters, and lots of other parts if there's anything you need then try me!
And still got these 206 Gti nimrods
16", in fair condition with good tyres.
£80 collected no offers
[Image: 141b982818d3032d0297c4a6783e58a9.jpg]
[Image: 4bbf767c409833ea89711cee7d894ee7.jpg]
And a 16" steel with tyre (hankook)
£20 collected
[Image: 9069335a01b47b6ee570231c41a4c844.jpg]
[Image: 79c6f5870ad1893336f025cd3e260286.jpg]
And finally I have a set of genuine peugeot crankshaft bearings (not conrod bearings). I didn't end up using these as mine were ok when I checked.
£30 posted
Might be interested in wheels location dependent
DN14 0SY
Its a bit far. Would you be willing to courier. Or for me to set one up. Also want the spare. Maybe come to a deal. Also as these are 206 ones don't they need spacers?
They will need a 10mm spacer as the offset is et28 and 306 is et15-18 I think
Messaged
(03-02-2015, 01:22 PM)Sambarker Wrote: They will need a 10mm spacer as the offset is et28 and 306 is et15-18 I think
I can confirm this. You need 10mm on the rear or they will scrub. The fronts will fit but will be really far into the arch and may fowl on full lock.
Still gotz Conrods?
Suzuki Santana Vitara 1.9 Td (Xud9) 3Dr
I'll take some rods too if you've still got them
All conrods sold
Do you have longer wheel bolts to go with the nimrods? Oh, and any spacers? Shame they dont fit straight on Sad
Nimrods are sold
No I never had longer bolts for them as they came straight from a 206
I have some 10mm spacers, some 5mm spacers, loads of standard steel wheel and alloy wheel bolts, some extended tapered wheel bolts for steels/aftermarket wheels
  BakerBM Grp.N Engine Torque Reactor (lower mount) RetroPug 5 2,715 30-05-2017, 05:53 PM
Last Post: RetroPug
  Discs, Pads & PF Engine Mount mr_fish 1 1,743 23-09-2016, 07:56 AM
Last Post: mr_fish
  Powerflex diesel new design lower engine mount. Chris_90 5 2,900 20-12-2015, 04:30 PM
Last Post: Chris_90
