Late Boost??
Late Boost??
Hi all
My standard ph1 D turbo doesn't boost in second until 3.5k and 3k in 3rd 4th and 5th
is this normal or is something wrong? its standard apart from a straight through exhaust
cheers
steve
Should start around 2k depending on which bine you have
hmmm ill add that to the never ending list of things to fix
Something is wrong, Is it chuffing black smoke? Do you have a boost gauge?
no smoke what so ever and I turned the pump up earlier? and no boost gauge as yet
My k14 wouldnt boost until 3k when i ran it maxxed out with a lucas.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
(02-02-2015, 08:32 PM)ADV_93 Wrote: My k14 wouldnt boost until 3k when i ran it maxxed out with a lucas.
are you talking full boost? because that's where it should be by then.
yes, full boost at 3k
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
done cambelt kit, made sure there was no boost leaks, gave the pump a tweak and it goes a lot better now,
also ditched the standard air box but not sure if I can put up with the extra noise lol
  late XUD tensioner Piggy 2 1,266 17-10-2015, 10:36 AM
Last Post: Piggy
