PH3 remote central locking key replacement
when i bought my HDI I only had 1 Key, no security pass, and the remote locking didnt work!
this guide will show you how to replace the original remote fob for an after market remote fob so you can get the central locking working again
this method will only work if the system still works!
to test if it does put the key in the drivers door and lock the car all doors should lock
if it does were good to go
[attachment=20244]
as you can see i bought a kit from ebay that was shipped from Bulgaria it cost £12
the instructions were in russian i think! but the drawings are quite good
[attachment=20245]
reading the drawing i needed to find certain wires on the car and the easyest place to acsess all of them together was at the texton box in the centre dash behind the hazared switch
to acsess this you need to remove the handbrake console complete, then the texton box will drop out the opening from the underside of the dash once the screws are removed.
all the wires you need are on the two plugs yellow and black
where are the wires...
Black plug
Pin 1 = Bat+ (BC81)
Pin 13 = Ground (M820)
Pin 2 = Indicator wire (2336)
Pin 10 = Indicator wire (2346)
Yellow Plug
Pin 4 = Unlock wire (6230)
Pin 17 = Lock wire (6250)
now its a case of connecting the wires as per the drawing bellow
[attachment=20247]
test it and all should be good
the kit i bought wont deadlock the car if you need that the kit needs to be able to give an extended lock pulse/duble pulse
remember to swap over your IMMO chip to the new Key case or the car wont start
Thanks given by: cpg21
Got a link for the kit mate as got a friend with exactly same issue, 1 key, no code but all working
Current cars
Subaru Impreza 2.0d - Daily
(23-11-2014, 09:01 PM)td_dan Wrote: Got a link for the kit mate as got a friend with exactly same issue, 1 key, no code but all working
http://www.ebay.co.uk/itm/111460068241
Thanks for this! I bought one of these kits a while back but never attempted to wire it up as there weren't any instructions. I'll give it a go, at least the box won't be rolling around in my boot anymore.
alright mate i dont spose u could put up a new link to what kit u brought as the old one has expired? cheers
  Central locking/deadlocking/immobiliser going beserk. pug306driver 5 4,464 29-01-2022, 09:29 PM
Last Post: pug306driver
  central locking bypass auto unlocking andyw 1 2,754 04-07-2021, 03:58 PM
Last Post: Mighty306
  Universal remote central locking carrot 1 3,261 19-02-2021, 07:58 AM
