darrenjlobb's Rolling Road Chassis Dyno Project
#61
ouch! going to need new springs up front then!
Not sure weight matters so much when you fit a cummins surely?!
When a cummins is normally in a 5tonne truck and its going into a 2tonne disco!
Great progress here pal. Going to need to get yourself some decent cooling fans too!!! In fact I have a massive 3ph extractor fan which your welcome to for postage costs. I'll get a pic up tomorrow.
Also I can see where some supercharged fine tuning can take place next year Big Grin
HDi Cabby Project Click
Bloody thing isn't even assembled yet and everyone is booking their time slot lol
(05-11-2014, 05:47 PM)Piggy Wrote: Not sure weight matters so much when you fit a cummins surely?!
It's going in a 90!
Oh sorry, confused myself...
Thats even more awesome!!
In fact I saw this done at Landrover Festival this year!!
Lifted suspension, custom cage, proper machine...
Will try and find the pics and video of it running...sounded like hell in a barrell!
they do this quite often tbh in the landy world..
there are some smaller cummins engines that work well.,
and i present to you... thus..
http://www.landyzone.co.uk/lz/f7/doing-i...75358.html
/Toseland
(05-11-2014, 07:16 PM)londondan86 Wrote: Great progress here pal. Going to need to get yourself some decent cooling fans too!!! In fact I have a massive 3ph extractor fan which your welcome to for postage costs. I'll get a pic up tomorrow.
Would be interested in that chap, let me know the details....I have already sorted a big blower for in front the car, but another wouldnt do any harm, also needing exhaust extraction although given the very short distance it has to go to get outside, im tempted by a tube straight out the wall with way of sealing to the exhaust, but an extractor would be better.
[Image: sigi-2.png]
(06-11-2014, 12:44 AM)toseland Wrote: they do this quite often tbh in the landy world..
God I want one now Smile
Pm'd Darren. It's a propper extractor with full housing. I'll get some pics tomorrow as I said Smile
Cheers mate really appreciate it.
[Image: sigi-2.png]
This is the beast!
[attachment=19945]
[attachment=19946]
[attachment=19947]
Ah, thanks chap, that may well work well for an exhaust extractor. Will be in touch via PM again.
[Image: sigi-2.png]
Mini update,
Got a load of parts together, various bearings, springs, spring cups, rubber bellows and ceramic faces:
[Image: qbHlBhynCGYNpKcazUrdw6iGo4_fw4u1eANj4-rL...16-h987-no]
Got the center cartridges back together today.
Started by fitting new bearings to the main shaft to test before packing with grease:
[Image: IMG_20141113_115905.jpg]
But after fitting found the new bearings I had were to wide on the shoulder, and meant the shaft didnt protrude quite the same which would have caused issues with rotor / stator clearance down the line.
To tore it apart again and raided the local bearing store for some, and finally found exactly what I was after:
[Image: 1QG-7svo2ATNw_Ou2MWjl0lhU_PudkBupZSoq648...40-h987-no]
So packed the tube with grease and fitted the shaft / locking collar, and then began work on the ceramic seal. After my international search I gave up trying to find a replacement, so went about changing it to accept a modern seal. which has involved basically using loads of parts from different seals (hence so many boxs) to make one that works, along with machining down the oem collar.
First step is to fit the stationary ring in the housing:
[Image: IMG_20141113_122137.jpg]
And then fit the bellows, mating face, spring, seat and modified collar:
[Image: IMG_20141113_122543.jpg]
And the two center cartridges all together / ready to accept the statr housings, which I'm still working on:
[Image: IMG_20141113_171245.jpg]
[Image: sigi-2.png]
Good progress mate. Well done Smile
How did the electrolysis work out in the end, was intreaged in the last vid?
Interesting stuff, shame I didn't see this sooner as two of our machines in work have rotary ceramic seals. I could find the company that repaired them if needed? Top work btw :-)
Good progress mate Smile
Dug a hole in the workshop the other evening, just slightly bigger than the frame of the dyno, to allow to bolt it down / route some pipes in front of it. Dug by hand etc but had kango for the concrete, although typically we ran into a bloody foundation underneath!
The hole appearing:
[Image: IMG_20141117_192901.jpg]
[Image: IMG_20141117_204137.jpg]
And then this evening I have shuttered up a level area and mixed / poured concrete in it. Bit tricky with the workshop levels being all to cock, but luckily when we built the pit, we built it level, so I am putting the dyno in level in front of it, and square to the pit, so cars should track correctly, but will obviously look a bit "wrong" to the levels in the workshop as it wont be quite the same, but its important its level!
[Image: IMG_20141118_160834.jpg]
Will let it set off for few days and then remove shutters / fill the edges up, and then ready to start building the frame in the hole. Due to the weight of the thing fully assembled, we are going to have to build it in the hole, as we have no means of getting over the hole with tractor and loader, and theres no chance we are dropping it in by hand, these things are severely heavy!!
Progress may slow for few weeks as have just pulled the tdi out landrover and nearly ready to drop a cummins in:
300TDI motor swinging:
[Image: IMG_20141116_140830.jpg]
Sat next to the cummins, which is now attached to box and transfer box:
[Image: IMG_20141116_155652.jpg]
I think the blower says it all really Tongue 2.5 4 cylinder vs 5.9 6 banger Smile
[Image: sigi-2.png]
That's heroic....
That Landy is going to be properly epic once thats shoe horned in there!
Good work Darren its all coming to shape . way is the make of that blower on the 5.9 it looks class :-)
Good to see some progress mate!! Where is the pit going to be in relation to the dyno? May want to set some anchor points to strap the cars down!!!
Is there a project thread coming for the landy??
The cummins has a HX35 on it, standard turbo, sadly it wont be getting tuned that hard, its not mine, a friends, but without putting mega bucks into axles etc it simply wont take much power, so its just getting a light tune on standard blower, either way, it will sound fantastic, and everyone loves a cummins Smile
Anyway back on topic,
The pit is behind the rollers, so fwd cars will be over the pit while on the dyno, and RWD not, idea being 99% of cars I do will be FWD, so that means they are fully inside / doors can stay closed when im working in the evenings / cold, as for RWD the nose will need to stick outside....
I will be mounting TWO larch anchors with straps preventing the car from pulling fowards, and also a left / right strap system at the front possibly to prevent sideways movement I think....
[Image: sigi-2.png]
Wow, this progressed pretty rapidly. Can't be far off now then eh?
Still quite a bit to do yet.... need to re assemble the frames, drop rollers back in, fix to floor, re assemble roller brake for loading, and then re assemble both water brakes (waiting on some small parts), then temporary rig up the old analog dials to see if the thing will work, and if so, order up some new load cells / data AQ stuff. oh and weld up some tie down points / design a pull down system to sit between the rollers im thinking...
[Image: sigi-2.png]
Getting there...
Nice work matey
Looking good mate as always.
I do love the cummins lump, its got a beautiful shape to it.
(18-11-2014, 07:37 PM)darrenjlobb Wrote: The cummins has a HX35 on it, standard turbo, sadly it wont be getting tuned that hard, its not mine, a friends, but without putting mega bucks into axles etc it simply wont take much power, so its just getting a light tune on standard blower, either way, it will sound fantastic, and everyone loves a cummins Smile
The pit is behind the rollers, so fwd cars will be over the pit while on the dyno, and RWD not, idea being 99% of cars I do will be FWD, so that means they are fully inside / doors can stay closed when im working in the evenings / cold, as for RWD the nose will need to stick outside purely to prevent sideways movement....
ratchet strap across the roof!!! thatll do it lol
on a more serious note, in chatting with the guy near me.. he has 2 sets of ratcheting points, one left and right of the car, meaning the actual straps will attach to the front towing eye and be about 30degrees to the front of the car
he also has 2 heavy duty unistrut sections (galvanized steel) bolted into a small recess in the floor that he can use to tie the car down with on either side of the car.. he also has some bolt in anchor points for said unistrut
he mentioned that the handbrake in most cases is more than enough to keep the car still forward and back (unless its a suzuki one of course) and that he only anchors the wheels in the cases of some of his lighter, higher performance rally cars..
he didnt move mine when he had it on the rollers, handbrake and left and right straps to stop it swaying back and forward and it was good.
/Toseland
That or strap it to ya tractor darren! Haha!
Most dynos have tie down loops actually under the car, these work really well with the 306's chassis tie down loops.
  Reinstate The 25Year Rolling Road Tax Exemption Uberderv 9 1,671 21-02-2016, 09:15 AM
Last Post: welshpug
  Rolling road near darlington mossy1985 5 1,215 20-11-2014, 01:18 PM
Last Post: mossy1985
  FAO Anyone trying to contact the farmer (darrenjlobb) Tom 10 3,136 23-02-2014, 09:16 AM
Last Post: Atterz
