inlet mani studs
inlet mani studs
Wondering what thread the nuts are fir the inlet mani studs?
Need to extract them and dont want to use the original ones
Cheers
No smoke, No poke!
M8x1.25
M8x1.25 I'm fairly sure.
EDIT: Curt got there before me Tongue
Cheers guys! Anyone know how long the studs are? Was thinking of replacing with bolts to make it easier
No smoke, No poke!
Wouldn't really recommend it, the threads in the ali head are a lot weaker than the studs.
I prefer the Allen bolts myself over the studs
So much easier to remove, never stripped the threads with them see where your coming from with regards pulling the threads out but you know when a bolts tight if you go mad you will strip the threads
Team Doesn't own a 306
Trust me, done it enough times to know, you have about 2-3 chances with bolts before the head is either scrap or requires helicoiling.
The threads are not designed to have the manifolds hang off them whilst you tighten against the threads in the ally head. This is precisely why early XUD9s have bolts and later ones have studs. You cannot tighten the allen bolts to the point the gasket is well sealed without damaging the threads - the turning and tightening action just destroys the incredibly soft aluminium.
Think about putting a self tapper into a soft wall - once it's tight, it's fine - you can actually put a serious amount of force on it - try tightening that little bit more, you'll just pull everything out of the wall and be left with a hole because the wall is weak.
I'm a bolt snapper/stripper anyway, me and ali don't mix. So I'd rather have studs which you can have confidence in. Aluminium doesn't need an excuse to strip in my experience, I had it recently with my inlet. Put absolutely no force on it at all and it stripped the thread...
I certainly wouldn't swap studs for bolts, bit that's up to you.
Think I'll keep the studs then haha, was just curious if it was an option Smile
No smoke, No poke!
I use to use bolts, for a one off remove of mani bolts would be ok but my mani was off every 5 mins, now use studs ....
  Relocation Mani Query silverzx 4 1,681 02-05-2015, 09:00 PM
Last Post: Lolben91
  Exhaust and inlet manifold spacers and studs andyyy 1 1,161 15-03-2015, 01:51 AM
Last Post: zx_volcane
  DW8 intake mani on an XUD? 089 5 2,718 14-03-2015, 03:32 PM
Last Post: Ruan
