Engine Management Light after Cambelt Change
Just fired the car up after a cambelt change (cambelt, aux. pulleys & crank pulley) and have an engine management light up. Does the normal on at start-up then goes to extinguish very briefly once running, but comes on again.
Checked all connections that I removed, the air filter housing so TPS and MAF, but still there.
Anybody any obvious ideas, before I order a code reader?
What's a good reader....pp2000 or that Citroen one?
Have you knocked the cam position sensor? PP2000 and citroen lexia is the same peice of kit. A guy called Lee at PD developments sells them.
HDI Tuning Ltd
www.hdi-tuning.co.uk
(02-03-2014, 06:03 PM)pro_steve Wrote: Have you knocked the cam position sensor? PP2000 and citroen lexia is the same peice of kit. A guy called Lee at PD developments sells them.
I'll have a look, thanks.
It starts on the button though, and 'appears' to idle fine but I assume this the 'limp' mode?
You'd know if it was limp mode - no power and won't rev over 2500rpm. A royal pita basically lol.
A code reader is a damn good investment for any HDi owner, just make sure you buy a good one, PP2000/Lexia are even better. Personally i'd get the code reader on it before trying anything else, could be something really simple.
Not that much of a pain, can keep a HDi under 2.5k easily! lol
Tbh, if you removed the battery, even that can log odd faults on the HDi.... I had one last year after a clutch change something to do with automatic transmission. lol Just cleared it and it was fine ever since...
Borrowed a reader off a colleague....TPS fault. Think I reconnected the battery whilst it was still disconnected.
Anyway, cleared the fault and it appears to be OK now. Happy days!
was going to say its probably a sensor fault. Glad you got it sorted quickly!
  Engine light always on and had slight run-on CaptainHair 0 1,001 02-07-2020, 08:54 PM
Last Post: CaptainHair
  Noisy Engine After Cambelt Change tigerstyle 13 9,244 18-02-2017, 07:12 PM
Last Post: toseland
  Engine management light came on ,, 306 hdi barnesy213 10 4,324 25-05-2016, 07:08 PM
Last Post: DeeTurbo
