8x 10mm Hubcentric Wheel Spaces And Bolts
For Sale: 8x 10mm Hubcentric Wheel Spaces And Bolts
Bit of an eBay blunder bought 4 wheel spacers perfect fit onto peugeot citroen hubs. But peugeot citroen alloys won't fit needs machining down to 65.1 demanded refund seller ignored then ended up with another set arriving in the post!
These are going to be machined down to 65.1 and will be a perfect fit. Or these can be machined to any size hub just ask!
2x spacers and bolts £35 posted
4x spacers and bolts £55 posted
Only 8 in total so be quick
[Image: 7E91DC91-8B89-476C-A469-A81FDB89B07C_zpswxapofgg.jpg]
www.prestige-auto-care.co.uk
are bolts flat or tapered jenks? Can't see on my phone mate Smile
Tapered matey
(17-01-2014, 09:36 PM)Jenkosowls Wrote: Tapered matey
Ahh OK he mind, I need some 10mm for these mi16 wheels Undecided
Flat seated bolts needed? Can machine the bolts to be flat seated just no washers
Think you've had the same issue as me, is the outside CB 73mm or something? Gonna get mine machined down too, as the only cost me £25. Still need to find bolts/studs/nuts though.
[Image: sigcopy-1.jpg]
Yeah something like that doesn't need much off but they'll make good sets once I'v lathed them down
Yeah, guy I got mine from said they were for some OZ wheels or something, seems a lot of aftermarket stuff uses the same bore. But yeah, machined down they'll do just fine, I would do mine, but just found a full set with bolts, studs, nuts and taper-flat washers for £40, so just gonna get them and flog on the old ones I think!
Bumpy
still got these really need some 10mm ones to fit nimrods
A year on, i doubt it. But you never know!
wow looked at the date and thought thats not long ago. turns out its not 2014 Sad
  FOR SALE: 10mm spacers and bolts bashbarnard 0 991 19-02-2017, 05:06 PM
Last Post: bashbarnard
  Wheel bolts ct-hdi 13 2,977 21-09-2016, 05:05 PM
Last Post: Frosty
  FOR SALE: 10mm head daniel909 6 1,674 12-02-2016, 05:13 PM
Last Post: daniel909
