16-01-2014, 05:53 PM
I'm trying to find in the UK 2 bolts M10 x 1.25 bolt with 16mm thread length and 8.8 grade. The length can be longer and cut down on the 16mm.
Bolt search
16-01-2014, 06:03 PM
(This post was last modified: 16-01-2014, 06:08 PM by powerandtorque.)
Have you tried a local fastener supplier? They'll likely have them in stock.
Failing that, here's some M10 x 1.25 x 20mm setscrews at 50p each: http://www.margnor-online.co.uk/bolts/8-...ne?cat=233 And some M10 x 1.25 x 25mm setscrews at 64p each: http://www.hobbfast.co.uk/prod.php?subca...c_Fine_Set No experience of either company and no idea on shipping costs. I suspect it might end up cheaper just going to Peugeot if you can't buy them from a local supplier.
1990 Peugeot 205 GTi 1.9 // 1991 Peugeot 205 GTi 1.9 16v // 1992 Peugeot 205 GTi 1.9 // 1999 Peugeot 306 HDi Estate
I'm guessing this is for a stud and nut conversion? You can buy pre cut bolts off ebay
![]() Cancel that, just seen the 16mm thread length ![]() ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
16-01-2014, 06:19 PM
It'll be for using Berlingo/Partner P-bushes in place of the 306/Xsara ones which use an M8.
(wheel bolts / studs on Peugeot's are M12 x 1.25 btw)
01-03-2014, 08:49 PM
(16-01-2014, 06:19 PM)powerandtorque Wrote: It'll be for using Berlingo/Partner P-bushes in place of the 306/Xsara ones which use an M8. There was a thread somewhere of how to upgrade your p-bushes to berlingo ones and how they got around the bolt issue, I'm currently trying to find it lol ![]() the smokey old bus that sounds like a tractor...
01-03-2014, 09:18 PM
Local fastening shop had mine, over the counter, cut them down from 20mm ones, cost pence.
02-03-2014, 12:40 PM
So what exact size bolt do I need to buy, sorry being lazy
![]() ![]() the smokey old bus that sounds like a tractor... |
