Slight miss fire
Slight miss fire
Hi guys did a long trip Monday and noticed that up hill in 4th 5th at between 70-95 full throttle I would get a like hesitation or miss fire ever like 10-15 seconds but not always but more often than not. Any ideas?
running veg? Fuel starvation if its under load and at full throttle?
Coilpacks! Oh wait its not a Datsun..
Air in lines?
(03-01-2014, 11:51 AM)SRowell Wrote: running veg? Fuel starvation if its under load and at full throttle?
this for sure...
I get this on 100% veg...
or if fuel filter hasnt been changed in a while
this for sure...
+1, but only on full throttle unless like you say filter is mucky.
I had this on normal diesel noticed there was air in fuel lines so changed the fliter and seem to solve it... must have reseated the cap
Hmm had a filter not too long ago and no veg will maybe change filter again and see
IN tank pick up?
Also now my car is getting harder to start it wouldn't start at all for a few mins the other day :/
Check the run off lines on the injectors
Air getting in?
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Yeah I've tried looking for air before had all the filter apart And that where is the main points to look at
before you crank the car if you pump the grenade does it take a few pumps before it becomes hard? Are you running a lucas? is the pump damp? (could be drawing air from a knackard seal on the pump).
As for it also not starting...glow plugs all good?
Glow plugs a few weeks old bosch ones. I've got a lucas and yes it does take a few pumps to become hard
(08-01-2014, 10:20 AM)sherman306 Wrote: Glow plugs a few weeks old bosch ones. I've got a lucas and yes it does take a few pumps to become hard
Does it start easier once you've pumped the grenade?
Air getting in somewhere for sure.
Not sure will try when leaving work later if it is the pump it's time to put a bosch on there
Pumped the grenade no issues starting. Well no more than I'm used to Smile
Bypass the fuel filter housing temporarily and see if its better, if so get a new housing or bypass with an inline filter
[Image: av5ym8.jpg]
I have a couple inline filters for sale Wink
I work in a motorfactors I have lots forsale lol
  Slight starting issue, lumpy idle, etc Dazecoop 6 1,427 05-04-2016, 10:40 AM
Last Post: Iaitoo
  fire seals ! jonnynitro 8 1,514 07-07-2014, 02:18 AM
Last Post: Dave
  slight idle issue (video) jpderv 2 1,636 03-02-2013, 03:07 PM
Last Post: jpderv
