26-12-2013, 03:19 PM
is there 12 volts at the fuse or one side of the fuse if you remove it ?
Fuel pump drawings none starter problem
26-12-2013, 04:05 PM
(26-12-2013, 03:15 PM)cully Wrote: check fuse F35 15amp in the engine bay fuse box (26-12-2013, 03:19 PM)cully Wrote: is there 12 volts at the fuse or one side of the fuse if you remove it ? with the fuse on for the first 15 seconds when the ignition is on i have just about 11.5v, about the same at the relay at pin 4 and 5 at the relay... where would the next port of call be?
26-12-2013, 08:17 PM
your next port of call after you have power at the fuse.........
there is 2 connection joints between the fuse and the pump connector first one is the large connector block on the bulkhead behind the windsreen wiper motor second is not drawn very clear but i think it is in front of the gear stick here are some drawings of the pin outs and where to find them [attachment=12271] [attachment=12272]
26-12-2013, 08:23 PM
mc65 which is the earth point, according to peugeot is at the rear of the car near the n/s rear light cluster
26-12-2013, 08:45 PM
Cully the two plugs you have circled in green are under the glovebox.
26-12-2013, 08:48 PM
cool thankyou niall
27-12-2013, 01:21 AM
thanks for the replies guys, want to say thanks alot cully, after reading the data you sent me checked the wiring under the glovebox and found the blue wire was damaged and not making proper contact, cleaned it up and repaired it.
Then hey presto the 306 lives again, just about take a test run after refitting all parts etc and clearing up, fingers crossed and i will let you know how it goes
27-12-2013, 09:23 AM
excellent news
another 306 successfully brought back from the dead!
27-12-2013, 12:14 PM
Awesome work there you two!
What type of damage was it to the connector?
27-12-2013, 02:42 PM
(27-12-2013, 12:14 PM)DeeTurbo Wrote: Awesome work there you two! Yeah want to say a really big thanks to Cully probably would not of found the wire without him, just glad it was somewhere easy to access. I only found it by accident as well while i had the power probe connected up i started wiggling wires and it started beeping when i fiddled with it. After thinking about it, it would make sense, the wire clips in above the glovebox and was hanging down around the back of the centre console. I can only guess it has come loose someone has jumped in the car and caught it and this caused the loose connection. Anyway the blue wire in the block was not connecting probably and had some damage to it, look like it been rubbing on something, so cleaned it up, repaired it and recased it. Then put the connector back together properly and i got a live back to my lift pump. It was well worth finding the fault though rather than just running a live straight to the pump like you see on alot of 306 HDI's. This done, i have covered 60 miles since with no fuse, bar a bit of a rough idle from cold, thinking maf or egr may be an issue but it hadnt been run for a week and may have a bit of air in the system. This to sort and finish the stage 1 off on it. thanks once again for all the help
04-02-2014, 01:39 AM
Im having the exact same problems, tried relay with no help and then disconnected & reconnected the two plugs under the blower motor side.
Hopefully has solved the issue but I plan on cleaning all.my earths and replacing the battery in the near future anyhow!
05-02-2014, 02:14 AM
No issue has creeped back up. Would a duff battery lead to the lift pump not priming? Theres power to the dash and it cranks (slowly after a couple of attempts) but with ignition on i cant hear the pump running
06-02-2014, 09:36 AM
(05-02-2014, 02:14 AM)mcglynn Wrote: No issue has creeped back up. Would a duff battery lead to the lift pump not priming? Theres power to the dash and it cranks (slowly after a couple of attempts) but with ignition on i cant hear the pump running have you checked there is power at the lift pump when the ignition if first turned on (first ten seconds I believe it should read)
06-02-2014, 09:42 AM
It was really sttange, I was getting 3.5v with the ignition on & 7v with thr ignition off.
I checked EVERY earth, not sure what fixed it if im honest? By checked I mean took off and cleaned, and refitted. Cully advised me there was a connection under the wiper motor which I went looking for as a last resort. I got the scuttle panel and wipers etc all off to find there was no connection? It was when refitting all this it worked again. All fuses where fine checked earths continuity with multimeter etc. Relay changed for a different one. (Although both second hand). Battery changed with no luck either. When I refitted the wipers it worked. Im stumped. Thats just the connection for the wiper motor.
06-02-2014, 09:45 AM
hmm well if works wouldn't complain mate...
there is a relay in the fuseboard and also the connector underneath passenger side dash to check to for problems if you haven't already? thanks
06-02-2014, 09:48 AM
Had the connector under the dash in and out, seemed ok connection wise and no. Urn marks/corrosion.
What relay is it in the fuse box? Like you say its great its running but id love to know where the problematic area is.
06-02-2014, 09:52 AM
(06-02-2014, 09:48 AM)mcglynn Wrote: Had the connector under the dash in and out, seemed ok connection wise and no. Urn marks/corrosion. best way I suppose is to isolate area and check voltage and see where there is a drop in an area as that is what I did to isolate an area for it. Work through systematically until you get a voltage change.. Im not saying it is the relay for the lp but top row second in from right relay (should be black or grey) but everytime I fiddled with wiring and had a probe in this it would beep and the car would start pumping again hope this helps
06-02-2014, 09:54 AM
Ok thanks. When I had the brown relay out and crossed wires 4 & 8 on the connector the pump would run but the car wouldnt start.
I thought this may be cause the relay controls other items too
06-02-2014, 09:56 AM
(06-02-2014, 09:54 AM)mcglynn Wrote: Ok thanks. When I had the brown relay out and crossed wires 4 & 8 on the connector the pump would run but the car wouldnt start. if you go on google images and search for the relay it will show you which number controls what if you haven't got the data infront of you mate
06-02-2014, 09:57 AM
I seen the picture cully posted earlier in the thread which led me to join 4 & 8 as he mentioned.
It wouldnt start but the pump did run, I will see if the car still works ok today.
06-02-2014, 10:10 AM
(06-02-2014, 09:42 AM)mcglynn Wrote: Cully advised me there was a connection under the wiper motor which I went looking for as a last resort. yes the small connection is for the wiper motor the big black box is the main loom connection into the car it is a large plug or multyplug and by the looks of it, it seams quite wet! im guessing its been floating in water for a while maybe its corroded the connections?
06-02-2014, 10:19 AM
So do I remove that allan key and have a look in there?
Sorry cully the drain hole in there is bice and clean so I would hope it doesnt get submerged!?
08-12-2014, 07:45 PM
17-12-2014, 11:07 PM
Hi mate,
I never had the issue recurr thankfully, so can't comment further. Sorry for the late reply.
13-01-2015, 11:50 AM
Mine seems to be doing something similar, cant get it on diagnostics till later to check code but last night engine light came on and car wouldnt rev past 2.5k.
This morning it started (took abit more cranking than usual) but drove fine, was revving properly and at full power. then whilst overtaking a vehicle it just cutout, managed to pull over, cranked it continuously for 2 mins and it fired, drove but same problem as last night with no power and wouldnt rev past 2.5k Abit closer to work and it died again, same MO as before. started after alot of cranking, 100yards driving gently down the road then it died again. Got it towed the last 100 yards into work and now it wont start at all. Any help appreciated!!
13-01-2015, 02:16 PM
Dead lift pump by the sounds of it. Can you hear it running when you switch the ignition on?
13-01-2015, 02:38 PM
Lift pump is in the tank yeah?
Mechanic said he can hear it doing something but i havent heard it priming :/ im assuming its this or perhaps the relay that controls this?
14-01-2015, 06:42 PM
(13-01-2015, 02:38 PM)Matt-Rallye Wrote: Lift pump is in the tank yeah? yes lift pump is in the tank mate if the relay is burnt mate and damaged it wont work have you checked the relay yet? thanks
14-01-2015, 06:59 PM
Checked the relay and can't see any obvious damage and the lift pump is priming.
Replaced fuel filter and lift pump today which made... Zero difference. Pressure regulator on back of HP pump?
14-01-2015, 07:01 PM
(14-01-2015, 06:59 PM)Matt-Rallye Wrote: Checked the relay and can't see any obvious damage and the lift pump is priming. if you look at the hp from the top the right side or back has two torque bolts in which holds the regulator in.. have you checked your wiring is not damaged mate in the actual car, that was my fault broken blue wire under passenger dash |
Increasing fuel pump output? | JTaylor2005 | 7 | 1,939 |
06-06-2016, 10:00 PM Last Post: Ruan |
HP Fuel Pump FPR Bolts | BiG K | 13 | 2,451 |
30-05-2016, 06:30 PM Last Post: pug306driver |
Removing Hp fuel pump | Welshy_Pete | 8 | 1,820 |
24-05-2016, 01:42 PM Last Post: toseland |
