Torsion Bars/ARBs - Sizes and Sources
#31
(04-07-2014, 02:37 PM)welshpug Wrote: Indeed, with that response I would be particularly wary of anything they send out, mismatching trailing arms is not a clever idea!!
Are you after an axle for a 16v?
Yes mate. Not able to PM at moment as new member. Want to re-furb my rear beam but obv easier to get another and swap it- but want to be sure its the specific ZX 16v one!
That will be tricky, however I might know of some...
Ive had bad experience with IM axles...never did get my partial refund so will happily bad mouth them !!
[Image: sigi-2.png]
http://pages.ebay.com/link/?nav=item.vie...06&alt=web
Seen these torsion bars on evilbay what's the chances they are actually 24mm..?
That's an ARB not a torsion bar.
Front anti -roll bar
Vehicle type Engine legislative type Anti-roll bar diameter
3 doors .......... KFX ..........................17
5 doors ........... KFX ......................... 17
3 doors ........ NFZ-WJZ-WJY ..............18
5 doors ....... NFZ-WJZ-WJY-NFT ............ 18
cabriolet ..... NFZ-NFT-LFY-RFV ............... 18
3 doors ............ RHY ........................... 19
4 doors .......... KFX-NFZ-NFT ................ 19
5 doors ............... RHY .........................19
5 doors ....... LFY-KFX-NFT-NFZ ..............19
4 doors ........ WJZ-WJY-RHY-LFY ............. 20
5 doors ............ WJY-RFV .........................20
Enterprise ......... WJZ-WJY ........................21
3 doors ................LFY ..............................21
5 doors ..............LFY-RFV ......................21
estate ....................WJZ-RHY ...................... 21
rear suspension
Data : Torsion bars
Vehicle type Engine legislative type tyres Torsion bar
3 and 5 door ...................KFX 165/70 R13 18,7
3 and 5 door .................. KFX 175/70 R13 18,7
4 doors .........................KFX 165/70 R13 19,3
4 doors ........... KFX-NFZ-DJY-WJZ 175/70 R13 19,3
4 doors ........NFZ-DJY-WJZ-LFZ-LFY 185/65 R14 19,3
3 and 5 door ............ NFZ-DJY-WJZ 175/70 R13 19,3
3 and 5 door ......... NFZ-DJY-WJZ-LFZ-LFY 185/65 R14 19,3
cabriolet .............................all models all models 19,3
Overseas export .................. all models all models 20
Affaire ............................all models all models 20
3 and 5 door ..........................KFX ( LPG ) 185/65 R14 20
3 and 5 door .........LFY-NFZ-RHY-RFV-RFS 195/55 R15 20
estate .......................KFX-NFZ-DJY-WJZ 175/70 R13 20
estate .................... NFZ-DJY-WJZ-LFZ-LFY 185/65 R14 20
4 doors ..................KFX ( LPG ) LFY ( LPG ) 185/65 R14 21
estate ................................KFX-WJZ-NFZ 185/65 R14 21
estate ........................... NFZ-RHY-LFY-RFV 195/55 R15 21
Data : Anti-roll bar
Vehicle type Engine legislative type Anti-roll bar (/)
3 and 5 door ........................ KFX 18
estate ................................. KFX 18
3 and 5 door ... WJZ-NFZ-LFY-LFZ-DJY 19
4 doors ........... KFX-DJY-LFZ-LFY-NFZ 19
estate ......................... RFV-LFY-NFZ 19
cabriolet .......................... all models 19
3 and 5 door .........RHY-DHW-DHY-RFV 20
4 doors ........................ DHY-DHW-RFV 20
estate .......................................... RHY 20
Overseas export all models ; Excluding estate 20
4 doors .......................RHY-WJZ-LFY ( LPG ) 21
Grand export estate ................................... 21
estate ...................... LFZ-DJY-DHW-DHY-WJZ 21
3 and 5 door ....................................... RFS 24
Deteriorated road condition Reinforced suspension 24
(21-09-2014, 02:14 PM)welshpug Wrote: That's an ARB not a torsion bar.
my bad Blush still one thing that confuses me is the rear beams!!
Hi,
I own a citroen ZX volcane 1994.
I will be visiting the UK in a few weeks from now
looking for a shop to buy used/new(?) TB 21mm and ARB 24mm.
Can anyone suggest where I can buy these/order online?
I will be in the area of Hatfield.
thx Eyal
Just out of curiosity what size are tb's and arb's in a phase 1 2.0 xsi?
same as a gti6.
Thanks, wasnt sure if the 8v engines had different tb/arb than the 16v models
ok, so with many thanks to Jonny for letting me know how tired my car is, it is getting time to sort out the handling stuff Smile
i would like to stiffen the cabby just a little so it doesn't wallow into corners like a bus. how can i do this on the rear beam? front end is obv a different thread, and i have an idea of what to do there. but this is the first car i have ever had with an ARB. they have all been either solid beams, or leafers.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
hi all are the arb n tb in a phase 3 xsi same as gti6 as above i am unsure thanks
(26-02-2019, 08:48 AM)Quietone Wrote: hi all are the arb n tb in a phase 3 xsi same as gti6 as above i am unsure thanks
Yep.  20mm TB's & 24mm ARB.
  Stubborn torsion bars Mighty306 12 2,973 09-06-2017, 08:07 PM
Last Post: Mighty306
  Uprated torsion bars mossy1985 17 4,729 23-10-2014, 06:48 PM
Last Post: mossy1985
  Uprated front and rear arbs mossy1985 6 2,021 22-10-2014, 04:57 PM
