coolant leak
coolant leak
hi, i filled my car up with coolant when the engine was cold and then as i was drivimg i noticed smoke coming from the bonnet so i looked and there was all the coolant i put in come out of the over spill and heated up, i am always getting the light up on my dash to fill it as well, does any1 kno why this is happerning
Air blockage? water pump? Does it over heat?
when i rev it past 3,000 it tends to creap up a little but not much and goes back down when i cruise but that could also be from iduction kit as its not in the best place atm, and i dont really kno too much about were to ckeck for air blockage, or how to kno if the water pump needs replacing
Radiator cap failing
im having this problem ive bled the system with new fluid but im guessing its water pump as now and then im getting a slight screeching noise and its not auxiliary belt so maybe worth keeping an ear out for that
Have you bled the coolant system on top of the engine, it may be an air lock.
  Enough of a leak to be a concerning boost leak? MY95 27 4,081 14-03-2016, 07:18 PM
Last Post: Midnightclub
  306 hdi Coolant leak from temperature sensor scfc_151 6 1,655 24-05-2014, 12:51 PM
Last Post: scfc_151
