PH2 Ir Remote Not Operating the Drivers Door
Hi, I'm a newbie here and have just bought a 306 td and the ph2 ir not working! So i replaced the batteries and it works but it doesn't operate the drivers door! So i still have to lock it with the key! Is there anyone who can give some suggestions i would be most greatfull.
Cheers....
Motors broken I would think!
Simple it's French lol
It's common problem check motors and wires
(05-11-2013, 03:01 PM)underground375 Wrote: Motors broken I would think!
Ok, will check that. Thanks
(05-11-2013, 03:11 PM)MarkTD Wrote: Simple it's French lol
Thanks for your reply, I will check for that!
Can't believe no one said door looms!
(05-11-2013, 04:58 PM)Tom Wrote: Can't believe no one said door looms!
Thanks for your reply, Yes i've been reading about a little now and found some common problems people been having with the door wiring looms.
I will check it out Thanks.
This is what's up with mine
The door looms are a pain, but if you have the patience then its not that bad to repair
  drivers door loom wires pug306driver 3 1,554 27-11-2016, 06:29 PM
Last Post: BiG K
  PH3 RF Remote Key questions td163 2 1,089 21-05-2015, 11:00 PM
Last Post: td163
  Finally set about the drivers side door loom! wacker315 3 1,259 17-09-2014, 04:35 PM
Last Post: cully
