16-09-2013, 01:41 PM
Anyone know the size off hand, I seem to remember they are 10mm but a friend has said they are 3/8 unf....
If not ill whip one off.
Thanks
Jamie
Thanks
Jamie
Brake pipe nuts.....
If not ill whip one off. Thanks Jamie
16-09-2013, 01:50 PM
They are 11mm...
16-09-2013, 01:59 PM
16-09-2013, 02:01 PM
Most are m10x1
You will find a couple of m12 though on things like the compensator
16-09-2013, 02:26 PM
(16-09-2013, 02:01 PM)swampy Wrote: Most are m10x1 Just had a quick look and my M10 die won't go on and M12 seems way too big... My pipe that runs from rear compensator / flexi to the rear calliper has seized and snapped on removal, trying to order some ends and it seems everywhere says they are M10 but as I say the die won't go near it???????
16-09-2013, 02:40 PM
(This post was last modified: 16-09-2013, 02:41 PM by Rippthrough.)
M10 x 1mm, not M10 standard (which is 1.5mm).
Put an M10 die down it and you'll ruin the thread.
16-09-2013, 02:53 PM
Yeah I know, but was just seeing if I could catch the thread to see if it was M10 fine of not..... I'll have to take a gamble and order them in M10, thanks for that
Jamie
16-09-2013, 03:18 PM
Can 100% guarantee that the m10 unions are as said m10x1 its the industry standard these days for most cars
16-09-2013, 03:37 PM
Brake pipe failure | Mighty306 | 3 | 1,788 |
15-08-2020, 03:27 PM Last Post: ekjdm14 |
Do I buy? rear brake pipe corroded, covered in grease or other material pipes | Charlie0 | 3 | 7,030 |
18-04-2019, 10:14 AM Last Post: Mighty306 |
Plastic brake pipe clips | Mighty306 | 3 | 2,216 |
12-04-2018, 01:25 PM Last Post: Mighty306 |
