Can an abs ring be fitted to a cv joint
I got a fail on mine today (01 306 2.0hdi), phoned the factor, they said they only have the complete drive shaft, that's the way come but said to try ebay ect as I get a cv joint with the ring on it. failing that, I'd need to try and get one (ring) and use a blow torch as it's heat shrunk on
nah, just get a joint or shaft
Ok, and how easy/hard are they (cv) to fit
personally...would rather buy a whole shaft...such a horrid messy job doing a cv
(02-08-2013, 08:30 PM)Piggy Wrote: personally...would rather buy a whole shaft...such a horrid messy job doing a cv
+1 for that.
The amount of trouble you go through, if you can just get another shaft its far easier.
Just remember to be extra careful of those driveshaft oil seals!
I just bought 2 shafts, easier cleaner and well worth the extra £££ for less hassle
unless you have the problem I had with my hdi Doh lol
(02-08-2013, 08:51 PM)puglove Wrote: unless you have the problem I had with my hdi Doh lol
A spanner set loose in the hands of a tit?
I just bought a ring for 2 quid to try on my brothers shaft, worth a punt.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
(02-08-2013, 08:56 PM)C2K Wrote: I just bought a ring for 2 quid to try on my brothers shaft, worth a punt.
lmao close family?
Wink
Cheers guys, will have a better look at tomorrow, I see on the fail paper what it actually says.."offside front (abs ring) anti-lock braking system wiring excessively damaged (3.4.3)
Could it it's just the sensor
This is a car that's been in a lockup for a few months and and not moved and never had a warning light in 3 1/2 years, now this!
Never come across failed wiring, but the rings corrode badly and snap off.
As it happens, the ABS ring we got for 2 squid delivered on ebay tapped onto the cv joint no bother at all and the ABS light seems happy.
The wiring can foul on the tyre if the cable is not clipped back into place on the hub correctly.
If it's been sat for a while theres a high chance corrosion on the ring/sensor tip has occurred. Good luck, they're a pig to get out of the hub intact!
Yeah sensors fail quite often and as Gunt said, they are a right bastard to get out. Have a big hammer and drift at the ready!
  ABS sensor ring issue jim1500 3 2,245 22-06-2018, 01:08 PM
Last Post: jim1500
  Bottom ball joint sizes Xsikid 4 1,687 04-05-2016, 05:45 AM
Last Post: Paul_13
  Swapping reluctor ring on drums Petebob 6 1,783 28-07-2014, 08:35 PM
Last Post: Petebob
