seized/knackered bosch pump for spares!
Wanted: seized/knackered bosch pump for spares!
Basically, i need the top half of a bosch, so if anyone has a siezed or knackered pump get in touch, mines weeping fuel from the little o-ring inside and is dripping out of the little cap below the boost compensator pipe.
Anything considered Big Grin
Andy
nobody have anything?
Try sending Darren Lobb a PM. Ive heard his place is like a grave yard for old Bosch pumps and turbos lol
Its me thats fitting it / sorting it, im all out of 306 bodies , or at least "good" ones, as any spare get built into a good pump!
I have one how much you offering posted? PM
If they just need the top casing, can I buy the gov and cradle and valve head bolts off you rob-binns?
Im also looking for some parts out of one
rob binns whats wrong with your pump? can you split for parts as we got more interest above ^^^
Cheers
bump!
(29-07-2013, 12:01 PM)Daniel306 Wrote: Im also looking for some parts out of one
what ve parts are you looking for?
I have tons of bits, but no top hat
The lever assembly. Iv posted a photo in the wanted section
nobody have a top hat going??
I have a pump spare gimme a message mate or get Darren to message me on fb
[Image: VcvTtst.jpg]
bump!
Still on the lookout
I've got a semi-ecu you can take...?
the part i need all good? what do you mean by semi eci? not heard of that term before Tongue
A Bosch pump which is semi ECU controlled...?
As far as I'm aware, the only ECU control is the advance on the pump?
Ah right, what car are those off? i basically only need the top hat of it, would you sell that seperately??
andy
From a 406.
Top hat? The LDA cap?
I need some parts if your breaking it?
Sure; the pump as a whole is fairly useless on a car..
Whats your best price posted for the lever assembley?
[Image: images?q=tbn:ANd9GcQigC7tbd8pAjU3KSLw-Sd...GoVh5DO4-5]
top half for me if your breaking? 4 bolts around the outside unbolt and off she comes i believe, mines weeping fuel from a little o ring inside so im informed from mr lobb as hes seen it, fuels coming out of the little cap just below the boost compensator hose,
know what i mean? but i need it asap if possible Smile
So you need all of this?
[Image: S6301267.jpg]
Yeh pretty sure! (Darren step in here??) im not very clued up on the pumps tbh!! ill check and get back to you, why you selling it??
andy
Nope, that's just a photo off the net to help describe what you need
Thats what he needs yes, but off a 306 pump, mech or semi ecu, makes no odds.
ansome cheers darren Smile
I see; shoul be able to sort you out. When i'm next in the garage i'll fish around and see if i can take the pump apart without cheesing any bolts Doh
  Wanted: XUD Bosch Fuel Pump xstian 0 1,410 02-06-2020, 08:08 AM
Last Post: xstian
  Wanted: Bosch pump nominous 0 1,150 17-01-2018, 12:19 PM
Last Post: nominous
  Wanted: Modified bosch pump Chris_90 2 1,466 27-02-2017, 08:24 AM
Last Post: Chris_90
