HDi Dyno Results BIBLE
Right guys, as the thread in the XUD section a bible of peoples RR results
Can we go with the format of:
power BHP, Torque lb/ft - Mods/comments - Rolling road - user name
Ill try and keep the first post updated and in order of power levels. I've also shortened some peoples mod lists to fit on 1 line so feel free to check their posts to see the full spec.
Standard maps
98bhp , 162 lbs-ft - Only mods are straight through exhaust and a k&n air filter - dynod @ Ecosse Peugeot Specalists, Scotland - craig306hdi
Stage 1 maps
101bhp, 180lb/ft - Siemens ecu, pikey tuning box, egr blank, straight through exhaust and lots of leaks - autotronic developments - pete
127bhp, 208lb/ft - stage 1 mr whippy remap, straight through exhaust - autotronic developments - kentiiboii
130bhp, 200lb/ft - pro steve map, r70 pump, 1800frps, double midbox exhaust - dyno dynamics @ ray west - Poodle
133bhp, 218lb/ft - Whippy Stage 1 map, EGR, No filter -  Autotronix Developments sheffield - Hdikyle
Stage 2 maps
152bhp, 216lb/ft - Pro Steve limited torque map, 22psi boost, de EGR, VERY restrictive exhaust - "get dyno'd" Buckley - Londondan86
152bhp, 280lb/ft - HDi Tuning stage 2 map - Surrey Rolling Road - iigodiix
154.2bhp, 280lb/ft - Stage 2 map, 2.5" FMIC, Sachs paddle clutch, HKS air filter, 22psi, Straight through exhaust - autotronic developments - Arron
154.7bhp, 258lb/ft - Whippy stage 2 map, Jag x-type FMIC, induction kit - Dyno Dynamics @Torque of the devil - Dum-Dum
155.4bhp, 277 lb/ft - Prosteve stage 2 map, universal FMIC, straight through zorst. boost leak and sticky caliper - Bridgewater college - Midnightclub
161.?bhp, 275lb/ft - Whippy stage 2 map, Huge ebay FMIC, enclosed induction kit - Dyno Dynamics @Torque of the devil - Dum-Dum
163.5bhp, 277lb/ft - TB205 stage 2 map, 1800bar sensor, Medium ebay FMIC, K&N filter, 17.5psi - Dyno Dynamics @NovaTech - Dum-Dum
163.8bhp, 278 lb/ft - Jammapic Stage 2 map, FMIC, straight exhaust, cg 5 paddle clutch, aps lift pump, r70 - Autotune Ballymena - McGlyn
165.1bhp, 282lb/ft - Whippy stage 2 map, Huge ebay FMIC, enclosed induction kit, W/M kit - Dyno Dynamics @Torque of the devil - Dum-Dum
Stage 3 maps
173.9bhp, 235lb/ft - Pro Steve map, std rail & HP pump, IHI RHF5 1a turbo @23psi, GRS intercooler, S2000 filter - Willfield Motors - Toseland
179bhp, 308lb/ft - Pro_Steve map, KO3S Hybrid, longlife exhaust, r70 pump, 1800 sensor, pipercross filter, FMIC - Saxon motorsport - Slam wagon
189bhp, 358lb/ft - Self mapped, 1800bar sensor, walbro lift pump, r70 pump, GT17 hybrid, stainless exhaust, FMIC - Dynojet @AwesomeGTi - Jammapic
2.2HDi Engines
166.9bhp, 285lb/ft - 2.2HDi 16v (FUBAR) TB205 stage 1 map - Dyno Dynamics @ West Tuning - Dum-Dum
List up to date as of 27/11/2015
Mine/Emma's HDi - 155.4bhp, 277 lb/ft - Prosteve stage 2 map, universal FMIC, straight through zorst.. boost leak and sticky caliper.
(17-07-2013, 04:07 PM)Midnightclub Wrote: Mine/Emma's HDi - 155.4bhp, 277 lb/ft - Prosteve stage 2 map, universal FMIC, straight through zorst.. boost leak and sticky caliper.
What dyno/where mate?
My bad, i'll have to look at the graph for what brand the dyno is.. was done at bridgwater college dyno though (had only recently been calibrated before we visited)
Yes please Ruan, that would save a lot of future arguments Wink
133bhp 218lb/ft - Whippy Stage 1 map, EGR, No filter - Autotronix Developments sheffield - Hdikyle
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
152Bhp, 216 ftlb torque, Pro Steve limited torque map, 6/dt clutch setup, 22psi boost, de EGR, VERY restrictive exhaust. Done at "get dyno'd" Buckley. Londondan86
Graph
HDi Cabby Project Click
Brynllwynog2 ran 201hp and 240lbft with his HDi.. Has anyone come near that
JP
JP
Last time My 306 went to the dyno, it did something like this..
[Image: 988491_469083439842281_145885742_n.jpg]
236bhp and 415nm
[Image: IMG_20130221_110416.jpg]
Why does my power line look like a symetrical rainbow!! after seeing other cars pull strange results on them rollers im nor convinced at all
Have to see what it does on the autotronix rollers next weekend TMI
S2 HDi >click<
154bhp
280lbs/ft
Managed to find the graph for my HDi
[Image: IMAG0535.jpg]
Could we get a list of mods on those please chaps? Arron, what's the figures on there, can't read them..?
2.0 HDI, 1800bar rail sensor, upgraded lift pump, r70 hp pump, GT17 hybrid turbo, stainless exhaust, no cat, twin pass front mount intercooler, electronic boost controller Jammapic mapping.
189hp and 358lb/ft at AwesomeGTi on Dynojet rolling road.
[Image: PugHDiDyno_zpsea712dad.jpg]
JP
[Image: attachment.php?aid=10793]
154.2 HP
280lbs/ft
Mods: Universal 2.5 inch IC, Stage 2 mapping, Sachs paddle clutch. HKS super power flow reloaded air filter. 22psi. Straight through exhaust turbo back
S2 HDi >click<
154bhp
280lbs/ft
127bhp-208lb/ft- stage 1 mr whippy remap, straight through exhaust-autotronic developments-kentiiboii
(13-10-2013, 03:57 PM)Arron Wrote: 154.2 HP
280lbs/ft
(13-10-2013, 04:07 PM)kentiiboii Wrote: 127bhp-208lb/ft- stage 1 mr whippy remap, straight through exhaust-autotronic developments-kentiiboii
Good results from both lads. Cheers for the update Smile
We was only hdis there iirc. Both moonstone to.
(13-10-2013, 08:44 PM)kentiiboii Wrote: We was only hdis there iirc. Both moonstone to.
Not quite Wink
Mine, 101 bhp and 180 ft/lbs. Siemens ecu, egr blank, straight through exhaust, pikey tuning box and lots of leaks.
Not quite Wink
Oh yeah forgot your van :-)
Why am I a "stage 3" map? Has no-one else ever run on a Hybrid Turbo?
JP
JP
(14-10-2013, 07:10 PM)jammapic Wrote: Why am I a "stage 3" map? Has no-one else ever run on a Hybrid Turbo?
Cos you have all the bits required to be a stage 3 car; Custom map, R70 pump, 1800bar fps and a big turbo.
Jonny and Sean haven't posted and they are the only others to be anywhere near that level. I suppose Id go with 3 of the 4 upgrades necessary to class it as a stage 3 car.
Ahhh. Ok. I didn't know what made a "stage 3" car. Lol.
What sort of power and torque have other stage 3 motors made?
JP
JP
Not quite Wink
How's the economy on the tuning box?
Cos I'm getting pretty desperate for more power on the 406.
Thanks given by: andyyy
Get another 100 mile range off a full tank, so cant complain TBH! Last time worked the MPG out it was between 45-50, but I have the aerodynamics of a brick, a lead foot and carry some fair weight about. Feels abit more torquey to drive but It doesnt make a massive difference to the performance really...I'd still rather have a proper remap, but can't find anyone I trust who doesnt charge the earth..
(14-10-2013, 09:06 PM)jammapic Wrote: Ahhh. Ok. I didn't know what made a "stage 3" car. Lol.
Dunno thats my opinion of it mate.
As for other stage 3 cars there isnt any on here that are currently mapped so cant say, I suppose Chris is the best one to ask.
When you gonna be good enough at mapping to write me something for my 2.2?
Well it's EDC15, so pretty much identical to the ones I've done for 2.0 HDi's. It's just the boost control I am having trouble with at the moment (though that is much easier on an engine that actually came from the factory with it!!)
JP
JP
Im gonna run it off a 306 ecu and loom anyway Smile
Piece of doddle then
JP
98bhp , 162 lbs-ft , only mods are straight through exhaust and a k&n air filter was dynod at Ecosse Peugeot specialists , Boness , Scotland
(11-11-2013, 10:57 PM)craig306hdi Wrote: 98bhp , 162 lbs-ft , only mods are straight through exhaust and a k&n air filter was dynod at Ecosse Peugeot specialists , Boness , Scotland
Thats a really good result for an un mapped car. Shows how restrictive the exhausts are.
  My Dyno Results JTaylor2005 4 2,455 02-04-2016, 01:32 PM
Last Post: JTaylor2005
  HDI rolling road results the milkman 14 7,494 20-03-2014, 06:49 PM
Last Post: pugbug
