aux belt tension
aux belt tension
Roughly how many degrees should I be able to twist the aux belt at its longest run? Mine will go to 90 degrees quite easily but I'm not sure if its tight enough..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Has the belt been tensioned up properly?
For an HDi: Pull back and lock off the top auto tensioner, loosen the lower elliptical tensioner, adjust so it takes up the slack and retighten, then release the top tensioner - it will set the correct tension itself.
Ok I think I've down it backwards then, will sort it tomorrow.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
  Oil pump chain tension DeeTurbo 3 1,226 13-06-2017, 08:10 AM
Last Post: DeeTurbo
  help - aux belt tension rd070707 47 8,034 12-12-2012, 09:00 PM
Last Post: rd070707
