Rear Electric Window Conversion
Guide: Rear Electric Window Conversion
This is a guide for converting rear manual windows to electric
I did this on my p3 estate but the principles should be the same on p1/2
You will need:
• Both rear electric window regulators
• Centre console switch
• Window safety cut out switch
• 2 new rear door cards (or put up with the hole from the window winder)
• Relay
• Drill with 6mm hss bit
• 6 M6 bolts and nuts
• Flat head screw driver
• Needle nose pliers
• T? Torx bit
• 10mm socket
Step 1 - remove the door card
Pretty straight forward really, 1 torx screw inside the door pull then it is just clips around the bottom. Remove window winders, these do just pull off but are very stiff so I just let the door card do it once it was loose. The plastic surround for the door handle is just clipped in and also needs to be removed. Carefully get the flat head screwdriver in there at the bottom and lever it off. You then have to lift it up and over the door lock pin.
Step 2 - Removing the manual winder mechanism
With the door card off you will be confronted with lots of stick foam pads which need to be removed to get access to the glass and wiring, these can be carefully peeled back and reused but I got impatient and just ripped the things off and used duck tape when I had finished!
Loosely put the winder handle back on and wind the window down to the bottom to reveal the securing pin. You need to remove the metal securing clip from the back in order to release the pin.
This is the one of the most fiddly parts of the job and took me a while but be patient. Once this is removed you will find that the glass will come off the pin but don't actually remove it yet. Use one hand to support the bottom of the glass and the other to wind the window back to the top, once there secure the glass with cardboard so it doesn't drop back down.
Undo the 2 10mm brass colour nuts that secure the slider to the door and wiggle it free.
Next you need to drill out the 3 rivets that hold the manual winder to the car.
Step 3 - Fit the electric motor regulators
This is pretty much the reversal of step 2. Check that the wires you have taped up inside the door are the same as the ones on the motor you have, on mine one door had the p3 grey plug and the other door had the p2 plug so I had to do another trip to the scrappy to get the correct plug (may be worth checking this before you go and source your parts or just cut the wires from the donor car anyway just to be safe)
Next insert the sliders into the door and attach the brass bolts back on.
Mount the motor using your M6 nuts/bolts
Push the white securing pin back through the glass and replace the metal clip, the is the last fiddly bit and caused lots of scrapes and pain!!
Step 4 - Repeat for the other door
As above!!!!
Step 5 - Fit the switches in the centre console
You will probably have a little pot thing in there at the moment, just get your flat head in there and pop it out. You will see the yellow and blue plugs taped up under there for the switches, un tape them and fit them to the switch and clip the whole unit in.
Step 6 - Fit the window cut out switch
This goes by the headlight adjuster switch and passenger airbag key thingy. Pop out the whole panel and locate the plug. Push the switch in and connect it up
Step 6 - Fit the relay
This is a green relay and goes in the empty slot under the fuse box (p3) I only had one missing in mine but others may need to check the Haynes as to which one is needed.
Step 7 - Test
Before refitting the door cards, switch on the ignition and fully test the system, check that both windows go all the way down and back up and check the cut off switch.
Step 8 - Refit everything & Enjoy!
As with any guide, this is the way I have done it, there may be shorter ways of getting bits into place so any suggestions please post!!
HDi Cabby Project Click
ahh very good, piece of piss then, always wondered if it would be . . . Smile
Yea, really straight forward. That's why I wrote it up, I was always put off thinking it would be a pita. Yours is an xt anyway isn't it?
(19-05-2013, 06:19 PM)londondan86 Wrote: Yea, really straight forward. That's why I wrote it up, I was always put off thinking it would be a pita. Yours is an xt anyway isn't it?
no, i had an XR which is now the wife's, i've had a DT for a couple of years now . Smile
Ah, fair enough Smile You could always do the wife's!
narr . . . .that car starts and stops then fcuk the rest lol might see if the bits are there on the DT though . .Big Grin
Lol! Yea, do it. Everything should be there. Worst case scenario is that you will need to change the door looms but even that is plug and play at the bottom of the b pillar.
sweet, cheers for the info fella . .Smile
Ahh... the relay!!! I did mine a few years back but couldn't seem to get any power to the switches, in the end I just spliced a live from the cig lighter under the centre console and spliced it in to the switch loom. Forgot to check for a relay missing!
[Image: 306Green5DrSig.png]
Lol^ Its usually the only empty hole. Did it work?
(19-05-2013, 07:47 PM)londondan86 Wrote: Lol^ Its usually the only empty hole. Did it work?
Splicing in from the cig lighter? Yeah it worked, first time I used both windows at the same time though I blew the fuse so I upped it, never had a problem since.
might have a look at doing mine Smile
[Image: siggy1.jpg]
(20-05-2013, 02:45 PM)devils_fuel Wrote: might have a look at doing mine Smile
Do it mate, couple of hours work tops Smile
brilliant stuff! i have all the parts to do a rear conversion but... i already have electric windows :/
(20-05-2013, 07:00 PM)SRowell Wrote: brilliant stuff! i have all the parts to do a rear conversion but... i already have electric windows :/
Lol. Sell it as a complete kit then. I bet it will sell straight away Smile
hasnt for the past 2 years! D:
How much you want for the complete conversion?
Silver Five Door D-Tuurbo'! More Doors More Whores y0! Wink
I paid a tenner for each motor and a fiver for the switches and relay. I would expect around 25-30 plus postage would be a fair price. You may be better off dropping him a pm
My 306 hdi 1999 has the wiring all there I noticed near the handbrake.
(21-07-2013, 10:02 AM)Welshy_Pete Wrote: My 306 hdi 1999 has the wiring all there I noticed near the handbrake.
Yep, that will be the wiring for the switches. Pop off one of the rear door cards and check that the wiring goes into the doors next Smile
I'm selling electric rear window set up...
  GUIDE: Electric Dimming Rear View Mirror cully 33 17,635 18-08-2013, 09:11 AM
Last Post: cully
