20-07-2016, 05:47 PM
I'm so gutted I didn't get your moment on video and only caught 2 blurred pics. Me and Toselad was right there.
Cully's Bianca 6 R150 YVM
20-07-2016, 05:52 PM
(20-07-2016, 05:47 PM)Dum-Dum Wrote: I'm so gutted I didn't get your moment on video and only caught 2 blurred pics. Me and Toselad was right there. no pictures so it didn't happen https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
31-07-2016, 08:23 AM
Hmmm!
I'm still finding damage from the curb incident at pugfest! Just a heads up! with the Quaife LSD fitted it is very hard to detect a wheel bearing gone as you cannot spin the wheel freely the same as an open diff i had to remove the drive shaft from the hub befor i could feal the roughness of this one by hand, the car did get more noisy around corners and had more vibration though the floor though this hub was refurbed and fitted with new bearings April 2014 and was OK when i fitted the LSD before Pugfest I have exchanged it out for another hub ATM while I referb another pair of hubs https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
31-07-2016, 02:50 PM
Sounds like someone filing something lol.
HDi Owner for 200k/9 years
05-09-2016, 03:08 PM
since the engine has been built installed and run in i have now done 4500 miles
this has been broken down as...... sept 2015 installed new engine, 500miles run-in on shit mineral oil, oil changed to 5w40 fully synth castrol edge, February trackday Castle combe, June Trackday Llandow, june FCS 2hrs session, july Pugfest, a few good hoon's around the countryside so in all im really happy that an engine i built in my shed has done me proud! I have a trackday booked at cadwell park on the 12th sept so i thought it was about time for oil filters to be changed as i will be driving there and back from Devon so todays job was just that oil filters and a check over and a quick spin around the block! new oil and the car sounds sweet things to do for sunday leaving for cadwell day sort tools sort spares sort tyres fuel cans load it all https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
05-09-2016, 03:21 PM
good to see youre still happy with it! Ill have to look into engines myself seeing as it seems that ill be rebuilding the speedboat head. Have fun on the track day!
06-09-2016, 08:34 PM
Really pleasing to see you caring for the old girl mate,kinda makes me want another white 6?
10-09-2016, 09:29 AM
track day on Monday I've got to work tonight so its pack the car day for an early start tomorrow
think I've got most of it in https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
10-09-2016, 01:43 PM
I can't believe the difference between when you bought this and now.
10-09-2016, 02:20 PM
(10-09-2016, 01:43 PM)Dum-Dum Wrote: I can't believe the difference between when you bought this and now. had the car now for nearly 3 years 6 months if you look through the thread you will see repairs i did at the begining having to be done again like the front hubs. i think im on the 3rd replacement now :O 2 sets of dead bearings and a stripped carrier thread yes the car has come a long way from the "I saved it from the scrapyard Quote" back in april 2013 and to add to this thread of things done to the car so far I have a list Front brake line flexys front ball joint X2 front Wishbones X2 steering rack gator Handbrake cable O/s Front wheel bearing new s/h Radiator + bottom hose Cam belt +water pump + idlers aux idler pulley New Re-con rear beam New clutch Comp gear linkages Oil+ Filter change fitted strut brace from HDI changed the rear lights to std fixed the Tailgate central locking fixed the N/s central locking re fixed door trims re-glued fabric trims removed cleaned painted inlet manifold plugged resonator reverted back to STD air filter A/C fan switch mod repair battery terminals replaced rear beam mounts (rubber type) renew replace broken arch liners clean off paint under arches x4 clean off paint front lower cross member clean off paint front upper cross member removed black masked fronts returned to std replace gearbox drive-shaft oil seals x2 fitted new front fogs repaired alarm retro fitted RF central locking integrated into existing alarm cleaned up freed serviced 4 x brakes weld repair cracked engine cradle weld chock top engine mount weld repair rebuild drivers seat replace Radiator for new alloy type remove air-con pump + pipework relocate PAS pump into A/c position re-pipe PAS returns weld repair chassis box to outer cill under car replace rear engine mount for vibratec replace rear shocks for B4's replace rear beam mounts for solids replaced exhaust back to STD including CAT + BB replace drivers window plastic clip replace front hubs for 18mm + wheel bearings + BJ's replace track control arm replaced P-bushes for Partner type fit 16 row oil cooler + thermo plate replace O/S rear stub shaft oil filter service replace front shocks/springs for B8's+eubach remove replace engine + box + clutch for rebuilt unit remove engine bay AC pipework to bulkhead lightened flywheel lightened pulley enlarged throttle housing replace clutch cable replace gear selector pivet ball treat engine bay corrosion renew fuel lines with braided to injector rail replace 20mm rear bars for 21mm adjust hight fit quaife ATB remove quaife rebuild quaife refit quaife ATB replace lower both arms complete with Lemforder units replaced O/Side hub complete tracking gearbox oil engine service probably more too https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
13-09-2016, 07:36 PM
Cadwell park Trackday 12th September
we had planned to make this a three day trip Day 1 travel up Day 2 trackday Day 3 Travel home Day 1. First part of our trip was to cleethorpes just outside Grimsby, M5->M42->A42->M1->M18->M180->A180->A16. 320 miles used 38 ltrs of fuel to return 38MPG in the 6. good going i thought doing around 75mph all the way, we had no traffic hold ups and only made one stop on route. found our Premier Inn new home for two nights booked breakfast for next morning then went for a stroll along the seafront, Funny accents you northern lot, and gravy with everything what's that all about! found a Hungry horse pub for some tea wouldn't go there again! back to the Premier inn in the car park was this beast all 5Ltrs of it Day Two Up early for breakfast at 6:30 crap food left most of it wife demolished her helping. left hotel around 7:10 signing on was due to start at 7:30 punched the postcode into the sat nav Cadwell was 30 mins away, at-least the car will be warm for the noise test arrived at Cadwell about 8:10, found the other members from the gti6 forum that were going, two Nicely turned out Bianca Rallyes and an Eton charged blaze 6, later on a 5 306 turned up looked to be a fully tricked out track car in a lime green. change from my road wheels to my track tyres some nice newish R888's went and did noise test 92db @ 5K hmm my cars getting louder but all was fine as the limit was 105db parked up and went to sign on which turned straight into the drivers briefing same info as most other places with the same questions from the drivers time for sighting laps behind coarse car! wrist band for signing in wrist band for drivers brief sticker for car for noise test signed sticker for sighting laps from the sighting laps i could see this was going to be an epic day, this was not a flat circuit it had up hills,down hills, s's, and bloody hairpins, nothing like I've been to before coombe is flat with some bends Llandow is flat with some bends Cadwell is well, you can see why its nicknamed mini-Nurburgring the other guys went out so i tagged along hoping to follow some lines but they had been here before and my Balls wern't that big yet! so did a few laps at my pace to get to know the sequence of corners then came in to check tyres and fluids. adjusted pressures as the fronts were to high and the rears were to high and off we went again... i was enjoying myself Hall bends. are epic but getting it stopped for the Hairpin you can so easy out-brake yourself....Bad idea as there is little to no run-off in that area! Barn. Is a hard corner to set up for as it tightens but you need speed to enter the straight.. Coppice. this corner is something else its a flat straight into a left that climbs, how brave are you? at the beginning of the day i was changing down to 3rd to take this but at the end of the day i was taking this corner flat in 4th under power! not to be done with cold tyres Charlies. out of coppice you climb and turn into a blind corner keep wide then cut back aiming for the speaker pole in the distance you cant see yet then adjust for the final exit, Parkstraight. out of Charlies down hill then it rises again over the brow on power and down the gears to hard brakes to Park Park. this is tighter than it looks but you need speed on the exit Chris curve. POWER and hang on changing up the gears as i went, ATB diff working well stopping the understeer Gooseneck. ow man what a double corner getting it slowed, right followed by left that changes to downhill mid corner Mansfield. down hill slow it to a second gear hard right each time pacing this made me smile as the marshal had his feet up in his hut power up through the gears to one of my favourite combination The mountain. down the gears to 2nd, hard left then hard right to fast climb almost air at the top car goes so light the revs pick up at the traction changes Power again to Hall bends to do it all again but better Favourite corners! coppice, show you've got balls and do it! Gooseneck, for the shear amount of changes in one corner Mountain, just like a roller-coaster at the top Hall bends, got to be brave as no run off's in and out for sessions all day i racked up a total of 147 track miles about 67 laps using 40 ltrs of fuel 16.7MPG my tyres were excellent R888's did very well with the ATB diff I'm not killing the outside edges with understeer so the tyres are evenly worn across the face this is the first full track-day with the ATB and I'm well impressed i went out for my last session at about 4pm stayed out quite a long time, temperatures were under control and not climbing all in the car worked as it should very well all day i was changing back to my road tyres when i was offered a ride in the charged 6 oh yes please, grabbed my helmet and was in as it was close to 5pm track closing time, i think we managed 3 laps...an epic 3 laps being one of the last cars on the track i must say a welded cage and proper seats and harnesses make a big difference in a car oh and the extra horses too back to the paddock finish changing the wheels pack the car and say goodbye to everyone on the way back to Cleethorpes we stopped for a carvery in a pub which was a lot better that the stuff we ate the previous day Day 3 Home day reversed our trip of day one A16->A180->M180->M18->M1->A42->M42->M5 320 miles used 38 ltrs of fuel to return 38MPG in the 6. so it wern't a fluke! 38mpg on a run any way home now and unpacked the car which needs a good wash as its ate lots of flies the future of my 6.. i was spoilt going out in the charged 6 i would love that car but... its not what I want from my car I want a Sunday car I can take the wife across the moors and do the occasional track day Oh wait I have that now! what i really want... a Van so i can tow the car to track days further away so i can try more different circuits Humm https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
13-09-2016, 09:09 PM
Sounds like an epic day out mate, that is fabulous fuel economy considering the engine.
14-09-2016, 05:50 PM
Great writeup again, I've been going up to Oulton Park with one of my customers cars recently and that's another track you have to give a go hoping to take my 6 up
'09 Mercedes E320cdi wagon '99 306 gti6
14-09-2016, 07:27 PM
Nice write up Cully. Good to hear the car is going well!
14-09-2016, 07:45 PM
How long have I been saying to stop wasting money on combe and do a proper track day! About time!
14-09-2016, 08:32 PM
What a great write up, including heads up on the eateries. Sounds like you had a right blast
14-09-2016, 08:36 PM
good effort with those tyres man. really like this thread as there is no bull. its always lets get out and do it. a gti treated like it was meant to be used. keep it up
15-09-2016, 08:09 AM
glad that you had a good time! shame about the food though!
15-09-2016, 07:43 PM
19-09-2016, 12:43 PM
Think i've just decided where i'm going once there's finally some spare cash for a trackday! Great write up bud, and what a list from the post above!! :S
29-09-2016, 04:09 PM
in other news i now have a new Knob!
the old one the leather parted away at cadwell so i splashed out on a refurbed recovered Knob https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
01-11-2016, 10:43 AM
I've had a shit few weeks with home life of late, so when BHPtrackdays posted on my news-feed saying 3 places left for Castle Combe for the following Monday.
i checked my shift pattern which confirmed a day off so the choice was made! packed the car as normal on the sunday for early start on the monday 8 wheels 40 ltrs fuel jack chocks spares tools tarp helmet monday morning fill up with fuel full tank + 40ltrs V-power then off to Combe, got to Combe at 745am by hell was it foggy! couldnt see from one end of the padoc to the other went and signed on, then back to change car from road tyres onto R888's drivers brief at 830am then waited for sighting laps..... waited..... waited..... the track was so fog bound it was to dangerous to open so we waited some more... and waited.... and waited.... 1130 the sighting laps started it was still foggy on the main straight but the back side was in full sun, then 1200 they called an early dinner. 1300 they opened the track full open pit lane was still patchy fog but you could see through it the fog cleared and the rest of the day was on and off track as and when I had 1 spin all day my fault as i took to much speed entering Bobbies and ended up heading for the solar panels after a half spin no damage just sticky tyres full of sand which took a few laps to clear off 2 issues with the car which have arisen 1st is an annoying idle problem when hot which i cured by unplugging the power steering pressure sensor no idea how that effects it but it did. 2nd issue i need a new exhaust! as i started the day just passing noise test at 96db I needed earplugs for the drive home. the db reading has been getting higher after each track-day so i suspect Ether i have no Cat left or the two silencers are empty of packing now this will need sorting before the next track day as i belive i will not pass now so all in all a good day just i little slow to start https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
01-11-2016, 11:51 AM
Awesome work! Looking great on track as usual, shame about the exhaust failing, sounds like probably cat or similar is disintegrating!
PAS pressure sensor increases idle effort (and possibly idle speed setpoint too - not sure) to prevent stalling when load comes on the system. GTi6s have a long inlet manifold, so by the time the idle speed has dropped due to the load coming on the system, by the time the ICV has opened to allow more air in reaction to the speed drop, it's too little too late and the engine will nearly stall, especially if you're on the lockstops. Probably the sensor cutting in and out due to being faulty when warm...
01-11-2016, 12:34 PM
Looking great as always, loving the hedgehogs on the parcel shelf!
I am slowly going through the videos i took and working out lap times
the best i can find at the moment is 1:28 thats only 5 seconds faster than my wet lap back in February also found my spin...... to fast entry liftoff oversteer! driver error https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
01-11-2016, 09:58 PM
those bigger bars catching you out again?
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
02-11-2016, 09:22 AM
(02-11-2016, 08:53 AM)Matt-Rallye Wrote: Looks like the cars performing really well on track! I really do enjoy my time on track, the whole learning the cars caricteristics on the limit is the fun bit, you get to realise very small changes in weather/temp/tyres/tyre pressure can make a dramatic effect on the car, which then forces you to change driving styles or come in and change stuff till you find what you like https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
02-11-2016, 10:26 AM
yes the hedgehogs on the parcel shelf! amazing.
02-11-2016, 03:14 PM
(01-11-2016, 10:43 AM)cully Wrote: 2nd issue i need a new exhaust! I'm on this now! I have removed the cat back system the Cat Matrix is still intact but both Box's on the system are empty! they have a nice empty ring to them when taped! I have dropped the system into a local Exhaust manufacturer who are going to cut open and repack reweld both box's for £60 apparently they use good quality packing that dont degrade or blow out over time we will see https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly. |
cully's XU10J4RS | cully | 11 | 5,201 |
30-06-2016, 12:53 PM Last Post: welshpug |
Cully's Electric car ..T project | cully | 144 | 48,053 |
16-04-2016, 04:14 PM Last Post: cully |
