Changing electric window motor
Right my passenger side window packed up a while back just got my hands on a 2nd hand motor with the cables and the metal rail all attached
My question is how do I change it
Hiya,
Not the easiest thing to do but not as bad as replacing door wiring! There are several very informative videos on Youtube - some original Peugeot footage and other videos (some in French). Just search for the various steps.
for example, this one shows a demo https://www.youtube.com/watch?v=dcscDQj6FC0.
Don´t start taking it apart unless you know how to put it back together!
drill the rivets out remove motor and fit rivnuts to door skin and bolt motor back in place
GTI6 Info
Yeah easy enough as cully says, the plastic square that holds the glass on the motor just needs a Quarter turn to remove it
  Electric window switch help Aaron _d95 3 3,060 08-02-2020, 11:47 AM
Last Post: arronnjackson
  Removal of driver's side electric window switch balkan_bozo 10 3,549 04-07-2018, 03:03 PM
Last Post: pug306driver
  off side Electric window and door not working bluebenz1 1 1,645 01-05-2018, 10:07 AM
