20-03-2013, 08:48 PM
As some of you may have read in my other thread
http://306oc.co.uk/forum/thread-9215.html
I have decided to take the engine out and replace the engine loom and tidy up the engine aswell as sort out the oil leak i have at the back of the engine which i suspect to be turbo related so my question is
What would you recommend to do while the engine is out
I'm thinking so far a good clean so its spotless!
Replace the gaskets possibly including head gasket.
Make sure my timing is correct.
Also what other bits and pieces do you reckon i'll need.
I'm sorted parts wise as working for ECP has its benefits
Any advice will be good
James
James
