[SOLVED] Swapped tailgate - wiring problems
Hi there,
I swapped my tailgate over for another today, the new one is in better condition.
All was fine until I got to the wiring.
All of the wires are colour coded which helps, but no matter what combination of wires I tried, I can't get the brake lights to work (which is a bit dangerous).
The third brake light has been removed, as well as the wiring so I can't see that being the issue, but read on...
The battery light on the dash is constantly lit since doing this.
When I put my foot on the brake, I can hear a relay clicking, the battery light gets brighter, then I release the brake pedal and the relay clicks off and the battery light returns to dim.
Also, the clock on the centre console has gone dim.
I must have connected a wire wrong somewhere, but I can't work out which!
Any advice?
Solved - Fuse 28 blown.
Car history (starting Jan 2012):
106 1.1 Zest2 (Scrapped)
206 1.1 (Sold)
306 Dturbo (Totaled)
BMW 318i E46 (Sold)
306 Dturbo (Engine failure)
306 HDi Estate (Sold)
306 Dturbo in black (Sold)
205 1.9 GTI (Sold)
Golf GT TDI
A soon as I saw your battery light was on I knew it would be fuse 28. Does this when the rear wiper relay shorts out, that fuse runs lots of stuff too.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
  Odd wiper issue - Solved londondan86 22 7,250 21-10-2020, 05:51 PM
Last Post: Geepout
Wink Door Loom Swapped - Central Locking Fault! partybish 8 3,096 29-09-2017, 08:58 PM
Last Post: paulgtt
  Swapped ECU etc now won't start V8Rumble 6 1,793 13-07-2013, 04:04 PM
Last Post: spike2002
