21-11-2020, 01:31 PM
When I first got my current daily the drivers door was leaking. It was because the cut-out's in the door behind the door card hadn't been sealed up. (Don't know why someone had been in there). Anyway, I sealed it up with some plastic sheet cut to size and fixed in place with hot glue. That seemed to work ...kind of. The problem certainly wasn't as bad but not solved either.
A few months ago the drivers window dropped and I had to repair the regulator mechanism. Because when I opened it all up again I discovered the hot glue hadn't held in place I decided to try some waterproof tape. That has now lifted and is letting in water too. The drivers carpet is now really quite wet n starting to smell pretty funky
Anyone got ant suggestions re a product that will have some chance of finally sealing up these cutouts? Have searched online for a product specifically designed for the task but not found anything yet.
Cheers.
![Dodgy Dodgy](https://www.306oc.co.uk/forum/images/smilies/dodgy.png)
Cheers.
