Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
It's not that stupid crash sensor thing that trips out randomly sometimes on these cars?
Threads: 49
Do you know anyone with PP2K? I Think only fuel pressure, cranking speed, cam/crank synchronisation and immo probs will stop the injectors from opening. Unfortunately I don't think non specific code readers can get that kind of data. I personally wouldn't be using brake cleaner down the inlet.
Did you fit a new fuel pump? Is the intank pump buzzing away? Is the filter clean?
Threads: 49
I'd ask on here first if anyone has PP2K locally that can come and plug in. As far as I've read the EDC15C2 ECU is a pretty hardy unit so it's possible that it's fine.
27-07-2018, 12:18 PM
(This post was last modified: 27-07-2018, 12:18 PM by Ruan.)
Engine light will always stay on whilst the engine is stopped - until it has cam/crank sync and it's run it's post start tests and the engine is running, it'll stay on. Sounds like immobiliser to me in honesty, try and get some live data out of it and see if you're getting engine speed reported.
It won't attempt to start checking for cam/crank sync until it's happy it's got the crank signal and it can read engine speed. If you've got RPM readings in live data during cranking and it doesn't log a cam sync fault, it's got sync fine. If it's cam sync issues, you usually get a code for that pretty quickly, there's not fuel pressure faults to say that it's not making enough fuel pressure to start, worth checking in live data, but suspect it'll have it.
The inertia switch does nothing but interrupt power to the in tank pump, it won't stop the engine from starting if the in-tank pump is running.
You really need PP2k to diagnose this kinda stuff.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
Make sure the calibration is for the kit you have also - don't go putting 1800bar sensors on without the map, it'll never run right.
