06-07-2018, 09:32 PM
(This post was last modified: 16-07-2018, 09:00 PM by Smokey Smokes.)
Hi guys,
its almost mot time for my car and while iv been fixing other bits and bobs i realized the EML and Airbag light and a few others either didn't work or had the bulb removed lol -_-
so i replaced them and wasn't surprised when the EML and Airbag light was on so i bought Diagbox and got it hooked up and done a global test got a load of intermittent codes on the engine ecu so i cleared them and only 2 "permanent faults" remained.
I also cleared codes from the Airbag ECU and the BSI and the ABS light has always worked properly and PP2K confirmed no faults with the ABS.
Engine ECU Faults:
- Airflow meter open circuit or short, Flow too low. Permanent Fault
- Pre/post heating relay circuit, Open relay. Permanent Fault
BSI Faults:
- No reply engine management control unit. Permanent Fault
- Locking failure caused by left hand door latch. Intermittent Fault
- Locking failure caused by right hand door latch. Intermittent Fault
Airbag ECU Faults:
- Drivers module trigger, Open circuit. Permanent Fault
- Seat belt trigger (right) , Open circuit. Permanent Fault
- Front right side airbag ignition module fault. Permanent Fault
FIXED Broken seat wire - Seat belt trigger (left) , Open circuit. Permanent Fault
FIXED Broken seat wire - Left side module ignition module, Open circuit. Permanent Fault
The EML is off after clearing codes but the Airbag light is still on.
Anyways i am more bothered about the BSI and Airbag faults at the moment as i really want my central locking to work again and id like my airbags to work although i hope i never see them go off
So my central locking doesnt work , the RF remote doesnt work ive replaced the battery and still nothing , i have to open each door by hand like a car without central locking but when i open the drivers or passenger side door with the key it also opens the boot as usual so the boot seems unaffected any ideas based on the codes from PP2K ?
Thanks for any help guys :
Engine ECU Faults:
BSI Faults:
Airbag ECU Faults:
![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
