Removing ignition key barrel
Rainbow
Hello how do you remove the ignition key barrel.
I have removed all the plastic covers out of the way now. Just wanting to know what next as I will be getting another barrel sometime soon.
306 hdi
Thanks
remove small screw in the side of the lock assembly turn key to II i think and pull the lock barrel with the key
GTI6 Info
(13-01-2017, 12:40 PM)cully Wrote: remove small screw in the side of the lock assembly turn key to II i think and pull the lock barrel with the key
Yeah remove screw turn key to position 2 then there a metal clip push that in and pull barrel out.
Just had ago thanks.
  Key Barrel Welshy_Pete 0 929 09-01-2017, 01:39 AM
Last Post: Welshy_Pete
