ph2/3 indicator stalk
Wanted: ph2/3 indicator stalk
Anyone got these laying around? Snapped one of the egr bolts a while back and its had a boost leak which has gotten progressively worse ever since.
If i cant find them as ive got some somewhere, i could do with an inlet manifold gasket also.
EDIT: just after an indicator stalk now if anyone has one?
I'm pretty sure they are studs from the factory? I replaced mine with bolts with no extra fuss, maybe drilled out the threaded section for bolt clearance?
I have a spare elbow, but not sure that's what you want.
I think that may well be what i end up doing tbh, bolt might be a little stronger than what was there originally too
Bump, only after an indicator stalk now
Bump..
I've got spare 306 indicator and wiper stalks from a 2000/X Phase 3 model in good working order.
£10 delivered for the indicator stalk or £15 delivered for the pair sound reasonable?
I'll take the indicator stalk off your hands thanks, wiper is still all good!
PM me your paypal details?
All sorted, this can be closed etc..
  Steering Wheel, Clock Spring, Wiper/Indicator Stalk and Check Strap Kezzieboy 7 2,248 20-02-2016, 01:21 PM
Last Post: powerandtorque
  Wanted: Phase 1 indicator stalk bashbarnard 4 1,037 03-02-2016, 12:22 AM
Last Post: ConorTRG
Lightbulb Wanted: Indicator Stalk PH2 jonas306 1 942 09-09-2015, 10:52 PM
Last Post: Mattcheese31
