13-05-2015, 11:59 AM
Looking good mate
Congratulations on the new job aswell
Eddy's Red Rallye
Looking good mate
Congratulations on the new job aswell Astor 6 Fast road/track project
13-05-2015, 01:06 PM
Thanks mate. Looking forward to starting on monday, couldnt really ask for a better job to be honest
13-05-2015, 06:56 PM
Yeah I know what's your postion??
When start getting to use the trade account,need some goodies Astor 6 Fast road/track project
13-05-2015, 07:03 PM
Just mechanic really. Got 3 clio 172s in for stage 3 turbo conversions, clio williams for a 225 engine, clio 182 for high comp engine and jenveys and a v6 for a full service so plenty work to be done
14-05-2015, 12:55 PM
nice I'd love a job like that.how long till you get another clio
14-05-2015, 04:08 PM
Good work mate, it's the little things that make the difference.
14-05-2015, 04:33 PM
Thanks mate. Cant wait to get it out on track soon
07-06-2015, 10:26 PM
Well wasnt too bad a weekend down at combe. Gutted i didnt get out on track. Got around 100mile down on friday and my clutch started slipping pretty bad so didnt want to take a chance on track just incase i did break it and it would have been a long 320mile walk home :lmao
Was good to put a few names to faces too. So plans now are to stick a clutch in it this week and discuss with the boss what we are going to do as i have told him we can just have it as a work track toy and do whatever we decide to do to it, possible go turbo. 300bhp would do nice Anyway heres a few pics of the car at the minute. Decided to paint the skirts black as they were faded pretty bad then once i done them i thought f**k it, bottom of the front and rear bumper are getting done too.
29-06-2015, 10:25 PM
Well a little update as not much has been happening since FCS.
First off i decided to loose the EPAS all together as i find it better driving without apart from parking that is. Then last week i bought and fitted a set of DS2500 pads and brembo discs, A load better than the cheap discs and pads that was on. Waiting on some BakerBM mounts turning up as mine are pretty f**ked, keeps popping out of gear when letting off power! Decided to remove a lot of the unwanted wiring from the rear of the car then i decided i would have a look at the interior loom and move it so its not running under the seats as there is just no need. Managed to feed the wiring under the dash but there is a good 2 meters of unnecessary wiring what i have had to loop up 3-4 times and tie up behind the glove box. Will look into cutting and shortening that when i get time. Only wiring that now runs inside the car is the wiring for the fuel pump and rear lights. Ordered a set of aero catches today what should be here ready to fit by the weekend and hopefully next week will be getting an F2000 spoiler to go on B) Oh and finally i got rid of the pro race 3s as i just didnt really like them on the rallye and now back on cyclones.
01-07-2015, 10:36 PM
Done my clutch today finally, only been stipping since FCS :lmao Turned out there had been oil on the clutch causing the problem so fitted a new clutch and cleaned up the flywheel. Feels so much better now. Also fitted a BakerBM lower mount i had lying around and just waiting on the top and gearbox mount to arrive so i can get them fitted along with a set of aerocatches and a slimline fan. Also stripped the driver side calliper as it was sticking and picked up some carbon sheet we had lying around at work to make some dash vent blacks and new carbon top top go over the fuel pump as the original one keeps pipping out and i cant seem to get it to go back in!
Just as i got finished i pulled the car out the workshop to give it a quick road test and as i got back the heavens opened! Nice half hour thunderstorm and a power cut what stopped work for a good hour or so.
02-07-2015, 08:37 PM
02-07-2015, 09:16 PM
I really fancy a set of OZ F1s or some Enkei RPF1s
Fitted my aero carches today, slimlime fan shuld be here momday hopefully so will get that on next week. Been on making up a turbo manifold to see how it turns out. if its any good then I will start collecting parts ready for a nice winter turbo build ready for next year
Why did you get rid of the brembo ?? Too much noise
Turbo build sounds interesting,with your job now would be able to make kits up if you made a reliable setup?? Astor 6 Fast road/track project
03-07-2015, 11:19 AM
Brembos? I never had brembos on the rallye haha.
We would be able to supply and fit turbo conversions for a gti6 only thing is manifolds arent cheap. I have started making my own but to be honest its not the best manifold in the world as looks a bit shit but its for my car and will do me just fine. Could possibly look into having our own manifolds made up but then again thats all down to cast as well, all depends on what people want to spend and what power they would like? Check out our website to get a rough idea on clio prices but can see 306s being slightly more. http://www.clioturbo.co.uk/index.html Group N engine mounts have arrived today so going to get on fitting them.
03-07-2015, 10:19 PM
07-07-2015, 04:42 PM
Slim line fan fitted today with a switch on the dash for piece of mind. Also just got an Adaptronic ECU for the car today got it pretty cheap as its the same ECU we run on all our clio turbo conversions. Been messing on at work in our spare time mocking up a turbo manifold, Just need to test fit it to see how it fits then maybe get a couple made up later on once we know all fits well B)
19-08-2015, 11:33 PM
Well its been a little while now and I have not been giving the rallye much attention these past few week so decided I was fed up of the f**ked driverside wheel bearing so fitted 2 new bearings, painted the front brakes yellow, removed the stickers off the side and gave it a good wash and was.
Booked onto croft for a few sessions on the on saturday then the car will probably be coming off the road over the winter for a little TLC and some money spent on it. Hopefully get a decent cage in it, good suspension setup and a little engine work, not sure what yet tho? Only time will tell... if I keep it long enough that is :lol
22-08-2015, 07:21 PM
22-08-2015, 11:10 PM
Eddy's n/a Nile | eddy_gti6 | 158 | 18,479 |
07-06-2014, 11:18 PM Last Post: eddy_gti6 |
