10-06-2014, 10:21 AM
Abs light, stop light and air bag faults help
10-06-2014, 02:03 PM
The airbag faults will be related to the dodgy pretensioner cables under the seat. Pm cully for some of his resistors or have a search for how to do it yourself.
ABS is the rear wheel sensor, replace with new
10-06-2014, 02:08 PM
I'm not sure that it the ABS sensor? Looks more like the ABS unit at fault unless I'm reading it wrong?
10-06-2014, 02:09 PM
Says right hand rear wheel? Sounds sensor related to me!! lol
10-06-2014, 02:11 PM
Right hand rear wheel inlet/outlet solenoid valve...the valves are in the unit that stop or allow fluid to give the brake pumping effect.
10-06-2014, 02:17 PM
I think that's unrelated http://www.206info.co.uk/Forums/viewtopic/t=50040.html
I would clear the codes, take it for a blast and rescan. Might be worth putting it on pp2k to be sure
10-06-2014, 02:22 PM
That is the problem of generic fault codes lol. PP would be the way to go tbh.
10-06-2014, 09:27 PM
When I searched that code on google it said it was a switch for the break pedal ?
10-06-2014, 09:37 PM
Search long enough it gives about 5 or 6 different things lol.
Get some proper diags on there and try again. |
Engine light always on and had slight run-on | CaptainHair | 0 | 992 |
02-07-2020, 08:54 PM Last Post: CaptainHair |
Engine management light came on ,, 306 hdi | barnesy213 | 10 | 4,300 |
25-05-2016, 07:08 PM Last Post: DeeTurbo |
faults | pug306driver | 3 | 1,137 |
08-04-2016, 02:55 PM Last Post: pug306driver |
