06-06-2014, 09:11 AM
Clutch switch is only used to match revs during gearchanges or pulling away. Reduces chances of stalling and smoothes gearchanges... Don't think you'd notice any issues with a faulty one tbh though.
Hdi - non starter (sort of) New injectors PP2000 data inside
06-06-2014, 09:09 PM
Just wait until you've got it running properly, you'll wonder why you didn't move over before.
08-06-2014, 06:17 PM
Right got some injectors from the scrappy today, some 076's from a 307 :-D
The thing which struck me first is how wet my ones were when I took them out and also, the copper seals didn't fit properly at all! Chances are then that my injectors are probably good. Well I had already committed at this point so pressed on. Car fired up very well indeed (been struggling a bit lately) put it straight on pp to get some results to post up. Cylinder 3 is still a bit out from the others but much better than before. Does anyone know the actual tolerances or would anyone mind posting a pic of their healthy hdi? Took the car for a drive and it is much quieter but doesn't feel as quick. I'll give it a few days to settle down and see how it goes. Anyway here is the pic of one of the removed injectors, all were wet all the way up but 3 had this sludge near the tip too? Also is the pic of the latest pp data. [attachment=16675] [attachment=16676]
08-06-2014, 09:27 PM
Tolerances are ~2mm3/stroke iirc.
08-06-2014, 10:00 PM
Those tolerances look about the same as the HDis I've tested here.
![]() Its odd you say they seem quieter but slower....that's exactly how my 076s seemed as well. ![]()
09-06-2014, 09:46 AM
^ Cheers both, feel better about it now. Gave it a good blast today on the way to work and no cutting out as yet but lets see how it goes!!
Yep, definitely not pulling as hard Tom, not sure if possibly my f$cked 044's were chucking in too much fuel or what but its noticeably slower now ![]() May have to look into a S1 ![]()
09-06-2014, 01:15 PM
If it's been ran on red for a while then it's likely the injectors are knackered too. Red also comes from dirty tanks, have you cleaned the in tank lift pump?
If you're still having no luck, install 'Camstudio' and then video the screen of fuel pressure and fuel pressure regulator duty cycle under full load through the whole of third gear. Usually the intermittent immobiliser problem won't be making you cut out, but may sometimes prevent the car from starting. It's worth fixing that though, likely a problem with the aerial which goes around the ignition barrell. Steve
09-06-2014, 04:36 PM
(09-06-2014, 09:46 AM)londondan86 Wrote: ^ Cheers both, feel better about it now. Gave it a good blast today on the way to work and no cutting out as yet but lets see how it goes!! Good to hear its working...again lol. Hmm, not sure about the old injectors chucking too much in, mine wasn't smoky or anything, I literally just changed them due to noise and what I thought was a lack of power, but turned out to be quite a low map anyway. Definitely think theres something we're missing with these 076s though. I'd suggest PMing JP about a map price if you're after one. ![]() |
Data Logging? | JTaylor2005 | 19 | 2,769 |
20-08-2015, 08:10 PM Last Post: craig306 |
PP2000 help. Pics and videos inside 2.0 hdi | Paul_13 | 14 | 3,258 |
07-01-2015, 10:42 PM Last Post: Paul_13 |
Galletto 1260 won't read data | Hdi and proud of it | 7 | 2,849 |
21-10-2014, 09:48 PM Last Post: Hdi and proud of it |
