You could try getting a CG clutch, they're very cheap for uprated. Get what you pay for at the end of the day though, will you mind having to replace it if it shits itself..? If not drash on with the cheaper stuff and let us know if we can get away with it too.
Threads: 6
Car Model/Spec: 2000 HDi Dturbo: Stage 2
17-01-2013, 07:50 PM
(This post was last modified: 17-01-2013, 07:54 PM by Adam Canning WSG.)
(16-01-2013, 11:47 PM)sam Wrote: Looking good chap what stage you doing?? Havent seen a hdi with a tdo4 yet like to see how this goes
cheers lad, going stage 2, hope to get a few videos up wen shes finished, cus not many people have good hdi acceleration videos and stuff up
(17-01-2013, 09:17 AM)Poodle Wrote: You could try getting a CG clutch, they're very cheap for uprated. Get what you pay for at the end of the day though, will you mind having to replace it if it shits itself..? If not drash on with the cheaper stuff and let us know if we can get away with it too. ![Big Grin Big Grin](https://www.306oc.co.uk/forum/images/smilies/biggrin.png)
tbh i just went for the cheapest clutch i could find that was advertised to handle stage 2 lol, i will let everyone know how it goes, and if it goes well it will be a win for the whole 306 community :p
the mock setup for intercooler, radiator, fans, and wiring
Threads: 6
engine set in for mock up, with bay mounted turbo
Threads: 141
35
is that a gearbox mounted td04?
good effort though, gearbox mounted turbos are the way forward
Threads: 6
(18-01-2013, 06:56 PM)ozonehostile Wrote: is that a gearbox mounted td04?
good effort though, gearbox mounted turbos are the way forward ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
it is indeed ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) cheers lad, cant wait to see it finished, i reckon it will look and drive like a beast lol
Threads: 6
Turbo set in, getting the intercooler piped now
Engine out for the last time, getting the exhaust pipes heat wrapped
How the exhaust pipes are sitting:
yellow = engine - turbo
orange = turbo
Red = Exhaust
(Blue = Air inlet bend)
Threads: 226
24
Car Model/Spec: A3 TDi
Im impressed your cracking on! The outlet on the turbo exhaust side looks a bit small :/
Threads: 6
26-01-2013, 05:55 PM
(This post was last modified: 26-01-2013, 06:06 PM by Adam Canning WSG.)
(26-01-2013, 04:02 PM)Tom Wrote: Im impressed your cracking on! The outlet on the turbo exhaust side looks a bit small :/
cheers lad ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) aww we made up custom adapter plates and the holes we made in them, we made to suit the exhaust pipe we had to work with, should give a great powwww noise when the wastegate opens
My show plate for the ultimate car show in larne - 24th of march
Threads: 6
29-01-2013, 08:22 PM
(This post was last modified: 29-01-2013, 08:22 PM by Adam Canning WSG.)
Picked up a handy wee set of half leather seats for cheap as chips, no pics as of yet, there currently being delivered, pics to follow
Threads: 6
Threads: 0
Threads: 6
(30-01-2013, 10:34 PM)fluffyhead69 Wrote: Very tidy motor!
Cheers mate
Threads: 6
31-01-2013, 10:36 PM
(This post was last modified: 31-01-2013, 10:52 PM by Adam Canning WSG.)
Few pics of the engine now, breather pipe for catch tank needs connected then the front end to go back on ![Tongue Tongue](https://www.306oc.co.uk/forum/images/smilies/tongue.png) she should be finished tomorrow night
-notice the all important cock on the R plate lol
-ECU bolted to suspension tower (getting heat shielded tomorrow)
-custom sprayed engine cover
-oil catch tank (oil draw off is the blue pipe, the other blank hole is for the breather pipe)
-custom bracket made up to mount the throttle body on, as it was previously mounted to the air box (now removed as you can see)
-induction cone fits nicely between the 2 intercooler pipes and still has the maf sensor attatched (will be removed when car is remapped)
-the pipe coming along the top is the water feed to the turbo, the return of this is not visible
-the black pipe on left hand side is the oil draw off to the catch tank
-the braided hose just below the oil draw off hose, is the oil return from the turbo, is it both braided and heatshielded to withstand high temperature and pressures
-notice how the maf sensor is still present, this is to keep the car running smoothly until it is mapped out
Threads: 13
Car Model/Spec: Feltspec white ph1 dturbo
its coming along well adam, engine bay looks the part, will be a mean looking thing with the front mount aswell
Threads: 6
01-02-2013, 05:36 PM
(This post was last modified: 01-02-2013, 05:36 PM by Adam Canning WSG.)
(01-02-2013, 11:03 AM)rickye Wrote: its coming along well adam, engine bay looks the part, will be a mean looking thing with the front mount aswell
thanks boss, she will definetly be noticed anywhere she goes i reckon :p
How it looks now that shes finished ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) might put mesh over the grill, but dont want it looking tacky ![Confused Confused](https://www.306oc.co.uk/forum/images/smilies/confused.png) will try and get a few videos up of how she pulls asap
Threads: 20
6
Any ideas on what sort of power your expecting?
Looks tidy though, nice work!
Threads: 119
Car Model/Spec: MG ZS180
Are you not going to change the angle of the turbo? I would be worried about the bearings not getting an even coat of oil, and as said about the seals failing.
Looks awesome though, very neat install.
Threads: 6
01-02-2013, 06:31 PM
(This post was last modified: 01-02-2013, 06:34 PM by Adam Canning WSG.)
(01-02-2013, 05:42 PM)Stephen Wrote: Any ideas on what sort of power your expecting?
thanks, estimating somewhere around 180bhp with a good map, but we will have to wait and see what can be achieved lol
(01-02-2013, 05:58 PM)Ricky Wrote: Are you not going to change the angle of the turbo? I would be worried about the bearings not getting an even coat of oil, and as said about the seals failing.
we reckon the turbo should be okay at the angle it is at, and it makes installing the water and oil feed and returns alot easier and neater, thanks mate, now for the hardest part of all.. paying for it lol
Threads: 6
very sad to announce everyone, but this project seems like a complete failure and a dead end at that ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png) put the car on the rolling road today and she put out 50bhp that is not a mistake people, YES! WSG put out only 50bhp ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png) this is a very sad day, and the guys at torquetronix actually refused to remap the car.. after much deliberation, we have come to the conclusion that the TD04 is the cause of such power loss in the car, we are now in the process of putting the old turbo back in and scrapping the TD04 and selling the mouting brackets, adapter plates, and exhaust pipes, i will keep everyone updated how it goes, but as for now, the project seems to be a failure, sorry everyone
50bhp.. i honestly didnt know these engines could put out that little power lol
Threads: 13
not good lad, all that work to end up being such a disappointment
but, if ur selling the turbo, dibs on it
Threads: 190
Car Model/Spec: HDI
so whats the explanation behind why the turbo was so bad?
Threads: 42
Car Model/Spec: 1.9 XUD
That seems very odd. Did you not drive it to the dyno and notice a serious lack of power?
How come you're blaming the turbo?
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Mate dont give up that easy, there must be a reason/fault behind this that can be sorted then you can go on a progress, chuck up a thread in the HDI section and seek some advice before you go ripping it apart,
Hope you can find a solution buddy, dont give up
Threads: 6
Just stood in the garage for 4 hours and missed dinner so we could do tests on every aspect on the cars airflow to try and see what te problem was, and we came up with the maf sensor ballsing the whole thing up, reverted my turbo back to standard before we found out that was the problem, and very sad now lol, need to fix back brakes as they as siezed, car will be back of out garage for the weekend hopefully running standard turbo, as a result of starting a new job on monday, i need the car back and do not have enough time to put the td04 back in ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png) as a result, im selling the whole kit turbo included, pm for more details ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) but project is back on, but without td04, but we know how to do it, so td04 may be back in in the future ladsss
Threads: 208
60
MTFU and keep it untill you get the chance to do it!
Threads: 6
Wee update
bought another set of half leathers, these ones with the grey leaf, got them for a steal too :p got myself a new caliper off a recently wrecked car as my front passenger side caliper is seized due to my agri-spec paint brush tactics of painting calipers :L also manage to scoop a set of vortexes (solid centres) with 4 great tyres for cheap cheap money, all in all, good past week, will get a few more pics of the seats tomorrow in the light, and the wheels whenever i get them on the car.. but until then heres these..
Also if this thread gets to 1500 views, i will upload a video of me going out by a Porsche boxter s in 4th gear (still havnt got s2 map)
