Cully's Bianca 6 R150 YVM
No need for session based days IMHO. Enough cheap open pit day providers.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
(12-06-2016, 04:58 PM)Piggy Wrote: How much was it for the day?
...but essentially the track time was after lunch?
Full open pit or sessions?
track day was £95
it was 10am-11am 8 sessions which i had two  full 15mins
then at 11am it went full open pit till 5pm minus 1/2hour for marshalls lunch
in total i did a full 2hours of track time according to gopro video looks like 130 track miles
good value for money
combe trackday cost me £195 for the same 130 miles
GTI6 Info
umm confession time!
it didn't all go swimmingly
I had to pin the throttle to save it from the tyre wall at one point whistle
GTI6 Info
(12-06-2016, 07:53 PM)cully Wrote: umm confession time!
Was that down to tyres mate?
good bloody save man, most people panic at that point and let off!!!
jesus, you were flying round that track fella, those tyre are well an truly destroyed lmao  good work fella. good work indeed.
the clip of your near spin/awsome save, is that from the bloke who span at the bus stop?
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
same incident from my camera !
that was the second session which the first N/side tyre gave up
the car started to turn, then i suspect the tyre shed its edge straightening the car to the wall
an extra handfull of lock brought the rear around power on to straighten the car......
back to the pits to change underwear and tyres Wink
(12-06-2016, 08:13 PM)insomaniac45 Wrote: jesus, you were flying round that track fella, those tyre are well an truly destroyed lmao   good work fella. good work indeed.
yes same guy
the reason he was behined is this Rofl
GTI6 Info
It must be a cully family thing to laugh at people when they go off!
(12-06-2016, 08:44 PM)Eeyore Wrote: It must be a cully family thing to laugh at people when they go off!
maybe  ninja
maybe just karma that after I chuckled I ended up towards the wall!
GTI6 Info
So you both fell off at the far end of the track on the same corner (don't say it's 2 corners, it's a double apex right) Greasy track me thinks.
yeah did look a little damp on that nearside!
/Toseland
post man delivered a package from Quaife Engineering Ltd
I now have my replacement sun gear!
have checked the shaft splines and yes they fit the spare drive shaft i have
so went on and built up the diff
I have also booked the garage ramps for next thursday for me to refit the diff
gives me a little time to get some gearbox oil and an exhaust joint kit
GTI6 Info
glad ure diff is sorted ive moved on to royal purple maxgear 75 90 seems to run a lot better. You can get it from aas in newburn 0191 267 3718
The ATB diff is officially fixed, fitted, and test driven
the car is now stable and don't pull to either side with the ATB fitted
stripped the std diff out in about an hour this-morning
refitted the ATB, on its wheels and test driving it in about 3 1/2 hours total
good going i recon Smile
well chuffed
GTI6 Info
Tongue
Good news bud now it's going to be flat oooooooooot :-)
Here i sit now with a bowl of nuts and a bottle of cider typing this......
Ive had a shit month!
buying a f*cked ATB Diff
fitting said Diff
removing said Diff
daughter having teeth pulled out having to fetch here from sussex
son causing all types off hastle at home because he turned into Kevin and perry big time
rebuilding said diff
refitting said diff
all sorts of other shit to that no one cares about but only stirs shit about,
the car pissed me off as it was still pulling to one side this time the opposite way
ive got a week off this week and not done anything for myself other than turned into mr grouch
been really considering selling up and f*cking it all off for something newer!
so yesterday i removed the long drive shaft removed the speedo drive nose and replaced it with the early box type with the shim
the reason for this was....
peugeot fitted two different speedo housings
1 with 10mm protrusion preload on the diff bearing
1 with 8.6mm protrusion preload on the diff bearing
the 8.6 casting is used with a 1.5mm bearing shim this adds an extra .1mm of preload to the diff bearing
my thought was maybe because warn diff bearings the diff is shifting in the casting causing the pull to one side
when i removed the speedo nose and measured it, it was 9.6mm with no shim HMMMMMMM!
the 8.6 casting is different as it uses different length bolts
so refitted the 8.6 with the 1.5mm shim
torqued it up and refitted everything
went for a drive yesterday and the car was a different animal,
anyway wife gone out tonight sat here bored.....
grabbed the keys and took Bianca out for a run
30mph speed limit, 40mph limit, unmarked copper Bastard i saw you Dodgy too many speed limits around here,
cheeky overtake to some clear road, and off straight to 60mph cars pulling well and pulling straight!
down the gears up the gears pulling straight
Im loving the diff power through the corners and off
ive had a cracking drive
hairs on my arms are raised arms are tingling adrenaline is raging
f*ck yeh!
i know why i bought this car
it makes me smile
and no its not for sale!
she is all parked up and waiting for the hill
see you all at Pugfest
Big Grin
GTI6 Info
Good news in the end.
Everybody loves a happy finish...
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
I can't believe all that faff with speedo housings, what a nightmare!
Glad to see you have it sorted. Nothing worse than just doing big jobs with no reward like taking the box on and off.
Had clutch issues years ago on my rover and felt exactly the same, box on off on off on off. Easy to get you down but puts a smile on your face when it's all come together.
Did you change the speedo housing when you fitted the atb in the first place? How come all the trouble with different parts of housings?
Never knew that!
Is that true of all the be boxes?!?
Least all is well....glad you didnt give up...Ive been there and felt the same at times...hope I can ride shotgun for a hillrun?
(07-07-2016, 10:41 PM)ozonehostile Wrote: Did you change the speedo housing when you fitted the atb in the first place? How come all the trouble with different parts of housings?
when i fitted the ATB i fitted it back as i took it off
the gearbox came from a low mileage car and was fitted when i fitted the rebuilt engine, Ive never had it apart
but who knows previous history
the strange thing was, when i fitted the rebuilt diff the second time the car drove spot on no pull or anything
the following day the pull was back but in the opposite direction
i put that down to bearing movement so went investigating
went to peugeot who printed me of a load of info
but even they said put back like for like
what i found was the N/S shaft puts a lot of load into the diff this would force the O/S diff bearing outer race outward tight against the speedo Nose
i also found the nose to be 9.6mm not 10mm this would add 0.4mm extra bearing play/diff movement
i need to look at that 9.6 nose again to see the finish as i suspect the bearing may have spun and eroded the speedo case giving the issue in the first place
(08-07-2016, 05:45 AM)Piggy Wrote: Never knew that!
I'm only going on what I've found by looking through service box for partnumbers and changes parts
[Image: gearbox.jpg]
[Image: shim.jpg]
GTI6 Info
Wow, fair play to you for investigating it!
some cracking photos around of my car this year from Pugfest!
respects and thanks goes to the photographers for sharing Smile
[Image: 13664313_10101386333031525_786688074_n.jpg]
[Image: bianca3.jpg]
[Image: pugfest3.jpg]
[Image: pugfest4.jpg]
[Image: bianca2.jpg]
[Image: bianca1.jpg]
[Image: pugfest2.jpg]
[Image: pugfest.jpg]
GTI6 Info
looking good! glad you got the diff all sorted!
How I imagine it was going down in the car  Rofl
Attached Files Thumbnail(s)
[Image: mcetg0.png]
haha legend ^
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
well after pugfest and the incident with the curbs at the esses
ive had to buy two new tyres and have the front re tracked as it was Knocked way out
now that is all done im looking at a 3 day road trip and track day in September to
Cadwell Park Circuit
Louth,
Lincolnshire
google says
266miles 4hrs 40mins no traffic
https://goo.gl/maps/FVXbGGPXKZ12
need to sort some leave from work then look at accommodation for a couple of nights
GTI6 Info
Cadwell is a decent little circuit, albeit a bike circuit. Used to be one of my locals and always enjoyed a trip there.
Watch out for the off camber bend near the start if it's damp! Spins many a car!
leave booked
Cadwell park track day booked for the 12th sept
now to find a B&B
as you can guess im not going to combe Forge action day on the 10th Sept
GTI6 Info
  cully's XU10J4RS cully 11 5,246 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 48,251 16-04-2016, 04:14 PM
Last Post: cully
