Threads: 138
72
Car Model/Spec: Mincebus
Given 0 thank(s) in 0 post(s)
Bloke on the 6 forum is selling some at the moment with good pics;
http://www.306gti6.com/forum/showthread.php?id=152060
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
(12-12-2012, 10:40 PM)Ed Doe Wrote: Bloke on the 6 forum is selling some at the moment with good pics;
That looks the same as what I got. Hope to get it fitted tomorrow after work
Threads: 138
72
Winner They're nice systems, I really like mine
Threads: 110
20
I got the exhaust fitted today. Pretty pleased with it! It just seems to sit out from the bumper a bit to much so needs a bit more adjust ment I think. Will try and get some pics
Threads: 110
20
Got the exhaust fitted a lot better now and am really happy with it. Love the sound of it!
Threads: 110
20
also forgot to say that it ticked over 120000 yesterday
Threads: 80
10
(13-12-2012, 07:43 PM)Frosty Wrote: I got the exhaust fitted today. Pretty pleased with it! It just seems to sit out from the bumper a bit to much so needs a bit more adjust ment I think. Will try and get some pics
Every Magnex i've seen does that, I think it's just the way they are built.
Serious.
Threads: 110
20
(18-12-2012, 01:34 PM)lewisdmz Wrote: (13-12-2012, 07:43 PM)Frosty Wrote: I got the exhaust fitted today. Pretty pleased with it! It just seems to sit out from the bumper a bit to much so needs a bit more adjust ment I think. Will try and get some pics
i got it fitted a lot better now though. a lot more pleased with it now
Threads: 110
20
Bit of an update but mostly bad news. Firstly i changed the cam belt and water pump on christmas eve (cuz i'm sad and don't have better things to do) and got it all put back together and started it up but it was making a really bad screeching noise. So i started to take bit back off until i found out that it was the cam belt cover rubbing so i losened it off for now. i hope to sort it out today after work and i think i know what it is. i will update later on how i get on.
I am glad i replaced the cam belt though as the water pump was really bad. It had a lot of play in it and was pretty noisey when i spun it up. I think it was only change about 3 years ago when the head gasket was done. Think the belt may have ben done up a little to tight.
And for the second bit of bad news it looks like i need to put another rear axle in.
It's not the end of the world as i have got a spare 1 but just something else to put on my to do list. It aint rubbering at the moment so not a massive rush to do it. I will prob do it when i fit my braided brake lines as they as easier to fit when the axle is off the car
Threads: 138
72
Crikey that's fair bit of camber (y0h!)
Threads: 110
20
It does look pretty bad. I had a feeling it was gone! I think it made a difference having it on a completely flat surface
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Copying me now mate :p let me know if you need a hand with the.beam
Threads: 110
20
(28-12-2012, 04:43 PM)rocker8742 Wrote: Copying me now mate :p let me know if you need a hand with the.beam
Thanks mate but I should be alright as I will do it down work on the ramp that makes it slot easier!
Threads: 164
25
If only mine was that easy lol
Threads: 110
20
I have sorted my cam belt cover rubbing noise which I'm pleased about. I had lost the rubber bit that goes on the pin that the cover locks into place on. That's 1 less thing to worry about now. Hopefully get the axle done in a couple of weeks time
Threads: 27
2
Car Model/Spec: 306 Rallye
Given 1 thank(s) in 1 post(s)
(28-12-2012, 01:39 PM)Frosty Wrote: Bit of an update but mostly bad news. Firstly i changed the cam belt and water pump on christmas eve (cuz i'm sad and don't have better things to do) and got it all put back together and started it up but it was making a really bad screeching noise. So i started to take bit back off until i found out that it was the cam belt cover rubbing so i losened it off for now. i hope to sort it out today after work and i think i know what it is. i will update later on how i get on.
It's not the end of the world as i have got a spare 1 but just something else to put on my to do list. It aint rubbering at the moment so not a massive rush to do it. I will prob do it when i fit my braided brake lines as they as easier to fit when the axle is off the car Lol people pay good money to get camber like that
306 Rallye giving people a surprise because they think shes a 1.6 ;-) Silly people
Threads: 198
135
29-12-2012, 11:48 AM
(This post was last modified: 29-12-2012, 11:48 AM by cwspellowe.)
(29-12-2012, 11:17 AM)hovis16 Wrote: Lol people pay good money to get camber like that
+1
Want
+1
Want
Threads: 110
20
What about camber like this that come into work the other day
Threads: 27
2
(29-12-2012, 01:20 PM)Frosty Wrote: What about camber like this that come into work the other day
Lol that looks costly
Threads: 110
20
Just a strut. They hit a pot hole, think they must if been going pretty quick though
Threads: 226
24
Car Model/Spec: A3 TDi
Mad camber bro!! In all seriousness though axles are failing all over the shop atm!
Threads: 110
20
(29-12-2012, 07:15 PM)Tom Wrote: Mad camber bro!! In all seriousness though axles are failing all over the shop atm!
Yeah they do seem to be but I suppose it doesn't help when most of us replace our knackered beams with 2nd hand beam that we can't be 100% on the history of. I guess the best way would be to get a reconditioned axle but that's very expensive
Threads: 110
20
Got a few bits turned up for this the other day. Firstly theres a set of longer bolts for the srut brace
and them fitted
and also got a set of braided brake lines
not fitted them yet as i will do the rears when i fit the rear axle and will do the fronts when i fit a gti6 master cylinder and also get another caliper painted to go back on
Threads: 110
20
Threads: 141
35
Car Model/Spec: 106 rallye, GTi6, Hdi dturbo
i really love this car. just sayin
Threads: 110
20
(20-01-2013, 12:53 PM)ozonehostile Wrote: i really love this car. just sayin
Cheers. Will be at the rolling road meet on the 2nd! Your car is pretty awesome, look forward to see it
Threads: 141
35
mine looks like a bag of shit currently, yellow bonnet and bent roof with boot full of crap. but who knows, might get some bits sorted before the 2nd so at least itl be fun to drive haha
Threads: 19
12
Car Model/Spec: Peugeot 309 GRD(T)
Given 25 thank(s) in 24 post(s)
look at how much snow you had! barely anything here and i'm not that far from you.
Threads: 110
20
(22-01-2013, 11:12 AM)mr_fish Wrote: look at how much snow you had! barely anything here and i'm not that far from you.
yeah i know it amazing how i had so much and just down the road had like nothing. I went to exeter on friday for my MOT course and there was like nothing andin honiton there was a fair bit
Threads: 110
20
