30-03-2014, 09:08 PM
As above needing one for 106 not in any rush just seeing what's about must be cheap as I'm tight and skint
![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
Wanted: battery relocation kit
30-03-2014, 09:12 PM
Make one yaself mate...I did it for about 15 quid
30-03-2014, 09:14 PM
(30-03-2014, 09:12 PM)Piggy Wrote: Make one yaself mate...I did it for about 15 quid Really? What size wires am I gonna need?
30-03-2014, 09:19 PM
Just work out the gauge and order it by the meter on ebay...5ms is plenty for positive and a meter for negative/earth
Then the required solder on ends ![]() Wishes for more power...
30-03-2014, 09:29 PM
Go to scrap yard
Pick up BMW rear battery leads Pay £5 for them as "its just a bit of cable" Run under car in copex to protect from element Mount battery (ensuring its vented to outside) Job done
Might be a daft question but why vented to the outside?
What gauge will I need? Looking at 300amp one 40mm'2 that to thick/over the top
just bought some cable to do mine 290 amp 35mm £20 for meters
£20 for 5 meters
31-03-2014, 09:14 AM
(30-03-2014, 10:29 PM)Teddy Wrote: just bought some cable to do mine 290 amp 35mm £20 for meters Is 35mm thick enough tho?
31-03-2014, 09:18 AM
Properly depends how big u battery is reading on gti6 forums they run 35mm with out any problems just need to make sure u get a sold earth for it
31-03-2014, 11:07 AM
get as big as you can afford
but as said, easy to buy by the meter and solder terminals on (solder like plumbing solder + blowtourch, not tiny little circuit soldering iron stuff) - welding wire is normally pretty good and flexible. or set of bmw cables has got to be good. also no one has mentioned putting a fuse in! I've got a big 300amp fuse between the positive battery terminal and everything else, just incase it decides to short itself on its route to the engine bay.
31-03-2014, 12:36 PM
Hmm a fuse! That's a good idea. Not got one on mine. I will get a breaker so can trip it to isolate battery
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
31-03-2014, 04:57 PM
Welding cable
31-03-2014, 09:04 PM
(This post was last modified: 31-03-2014, 09:05 PM by SupaStar88.)
Lol, this is effort!! But you want thicker than standard as you'll get a voltage drop cause of the extra distance
Using Tapatalk
Wanted: Battery relocation kit | Chris_90 | 5 | 2,128 |
02-06-2017, 07:35 AM Last Post: welshpug |
Wanted: battery relocation kit | Chris_90 | 9 | 2,697 |
30-07-2014, 08:09 PM Last Post: Chris_90 |
Wanted: Battery clamp for gti 6 battery box | SKoob | 2 | 1,697 |
19-09-2013, 11:58 AM Last Post: ginge191 |
