Threads: 25
Car Model/Spec: dturbo
As above, is there a guide with pictures for example showing the basic overview to doing it all. Yes i know everyones piping etc is different. But the main pointers of what to connect stuff to etc...
Thanks in advance.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
All you need to "connect" is the IC. From the turbo into the IC then IC to the inlet manni. Simples
FMIC is mounted at the front.
slim line fan is a good idea for this.
one pipe to turbo outlet...the other to the engine inlet.
may need grinder and "tapping" tool to make room for pipes
done
Threads: 11
Car Model/Spec: 306 1.6 Sold!!!!!
Too many acronyms
Threads: 87
48
why you wanna know? . . .you have a 1.6
(17-12-2012, 09:14 PM)Face. Wrote: Too many acronyms ![Huh Huh](https://www.306oc.co.uk/forum/images/smilies/huh.png)
FMIC/IC...thats really just one....and if you dont know that one its a bit pointless reading this step by step "guide"!@!
Threads: 87
48
i'll do a guide when i fit mine round Xmas or maybe new year . .
Threads: 541
124
Basically remove the standard fans (so you have space)
fit a slimline fan (or 2) using the standard wiring
Bolt the FMIC to the front of the car (buy nuts bolts and ally strip from B&Q)
Run a pipe from the turbo to one side of the intercooler
run a pipe from the other side of the cooler to the inlet
Simples.
You might need to hammer/grind a few bits to get space for pipes
Threads: 177
Get one wheelbarrow
Cut said wheelbarrow in half side ways
Markout and cut hole in bonnet to match
Superglue it inplace
Paint the car blue and the wheels gold
Threads: 11
(17-12-2012, 11:35 PM)Mattcheese31 Wrote: why you wanna know? . . .you have a 1.6 ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
Because I have a 1.6 for now but would love a XUD.
Threads: 87
48
(18-12-2012, 05:54 PM)Face. Wrote: (17-12-2012, 11:35 PM)Mattcheese31 Wrote: why you wanna know? . . .you have a 1.6 ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
have a read of the XUD section then mate . . .plenty of nice info and pics in there and good choice btw . .
Threads: 25
Where does the tiny pipe go that runs from the top of the bosch pump (beside the lda) into the bottom of the Top mounted standard one in the FMIC?
Threads: 141
35
(25-12-2012, 10:36 AM)GP123 Wrote: Where does the tiny pipe go that runs from the top of the bosch pump (beside the lda) into the bottom of the Top mounted standard one in the FMIC?
If your putting a fmic on, the boost compensator hose needs to join the pipe coming out of the intercooler into the inlet manifold. you can drill+tap a hole and screw in an adaptor for the boost compensation hose, or weld on a nipple to attach it to
Threads: 170
looks at my project thread i got a few pics from when i did mine
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 25
25-12-2012, 01:54 PM
(This post was last modified: 25-12-2012, 01:55 PM by GP123.)
Cheers lads, good help indeed.
Just hoping halfords is open tomorrow, so i can purchase a 2.5mm allen key for doing the KKK. lol! lost it
Threads: 25
Right the Front Mount Intercooler i have at each end it measures 2.5", so will the pipes i get have to be that little bit bigger than 2.5" to get over and clipped on?
Threads: 141
35
best way for it is use silicone hose to connect the solid pipe sections together. you can get silicone hose in 2.5 that will stretch just enough to fit over the 2.5 metal sections, maybe with a little washing up liquid if its really tight. make sure to use decent jubilee clips on every joint otherwise youl have a right headache with boost leaks popping up everywhere
