01-10-2014, 11:56 PM
Just want to check will the entire axle of a 1998 gti6 axle fit on my 2001 306 HDI? Also is there any differences in the two axles such as torsion bars brakes etc?
Thanks
Thanks
1998 gti6 Axle on 2001 HDI
Thanks
02-10-2014, 02:11 AM
Should be the same I think!
02-10-2014, 06:30 AM
Be slightly firmer. But will fit no problem. Assuming your hdi has discs which I think nearly all ph3 hdi's had
02-10-2014, 09:33 AM
yeh if both have discs its a decent swap. Should be a much stiffer beam too.
02-10-2014, 09:40 AM
All HDi's have rear discs. HDi DTurbo's use a GTi beam so if you have anything other than a DTurbo, it'll lower the height slightly and be firmer.
However the '98 beam probably has the brake bias valve which yours wont (can just be bypassed) BUT may not have the ABS sensors? |
B4/Eibach with GTI6 Rear Axle | MY95 | 3 | 1,221 |
24-01-2017, 10:49 PM Last Post: MY95 |
GTi6. beam bearings and stub axle measurements | Ben_w | 14 | 3,111 |
01-06-2015, 05:22 PM Last Post: Ben_w |
Gti6 axle on HDI? | LewisG | 5 | 1,693 |
08-03-2014, 04:19 PM Last Post: LewisG |
